annoying clicking noise
UrbanPuma
675
43
It could be that the computer (distance) sensor has shifted position, if you have one fitted. I get a clicking sound when mine is too close to the spokes - a slight adjustment is all that's required to realign it and clicking vanishes.
Reactions: Fir3mansam1964
Fir3mansam1964
14
Thanks but don't have one
Reactions: UrbanPuma
Deleted member 25121
I get clicking noises when there's a tiny stone or bit of dirt trapped inside the caliper and it rubs against part of the disc, you said you've had the pads replaced but there might still be something attached to the caliper.
Fir3mansam1964
14
Will check
3,993
We told him last Wednesday to check the spokes. 10 seconds later, he could have a solution to his problem or he could have eliminated it as a possibility. The same with the disc, two screws and 30 seconds and that could have been proven or eliminated. He obviously ony wants sympathy or company rather than his probem fixed. Start hating me now.
Reactions: ebiker99
What makes you think the OP hasn't tried those things?
Fir3mansam1964
14
OP I've been away on holiday since Wednesday and just back for father's Day.
I will try each suggestion and will let all know outcome sympathy I don't need, but appreciate the offer.
To all positive responders I thank you.
  • Dislike
Reactions: ebiker99
Sorry, I was trying to help you by being supportive. I wasn't offering any sympathy......
Fir3mansam1964
14
I feel so bad Ive miss understood your post , sorry if I've hurt your feelings , never my intention, I appreciate your ongoing support.
Thanks once more
Fir3mansam1964
14
Spend some time on the bike going through some of all your suggestions, checked all calipers, discs nothing found, invested in a small jars of vaseline and as suggested applied to the area where the spokes touch each other on the front wheel.
Rode it to work today and the clicking has reduced greatly.
Now it sounds to be coming from the back wheel only not as loud, I didn't grease that one as the spokes don't touch where they cross. I think I'm going to try and get some grease into the area near the hub where the j end of spoke attaches to the hub see if that helps.
Once again thanks to all contributers I wasn't ingoring your suggestions just didn't have access to bike whilst away on holls.
