Alternative Display and Controller for NCM (DAS-KIT)
kindbowl3115
Dec 5, 2023
Hi Paul
I have PMed you
J
Wondering if you could PM me as well with the instructions please? Have the NCM Milano Plus with the same type of DAS-KIT display that is limited when entering the codes on the display; only have adjustment of the 3 performance modes, tyre size, and voltage available. Many thanks!
Peter.Bridge
1,476
689
Could you just change tyre size ?
jokskot
159
47
76
Done :) J
Irish88
Apr 28, 2024
HI jokskot, could you pm me also please sir.
"I have a NCM prague and i want to buy another ncm moscow, can you please tell me how i can derestrict them, thank you"
andyshor
Do consider my solution before spending the £80 and several hours work advocated by Saneagle (formerly vfr*** ?)
I have pm'ed you. Please indicate you've received the mail.
8,685
When I had a Lishui DASKIT with the Oxydrive kit some many years ago, I simply replaced controller and display with a KT.
3,539
I've done the same. It functions much better and is easier to use. It's worth it just for that.
francesco
May 20, 2024
Ciao, ho un NCM Mosca. È possibile aumentare velocità e potenza. Dovrei usarlo fuoristrada nei boschi.
Grazie
Silvanien
Jun 5, 2024
Hello!
Does anyone know if kt display are compatible with ncm c7 controller ? Connector isn't but it's not a problem I can add a new one !
Regards !
8,685
No .
The ncm is likely a lishui or other brand, you will only see partial compatibililty . It will turn on and maybe show battery level but that is about it.
If you want a KT display then you must marry it to a KT controller for 100% compatibility and vice versa.
8,685
Finding compatible Lishui controller /display isn't easy they are in the main OEM only , even if you found a lishui dipslay it may not work as they are I believe programmed to work as a pair .
One reason why we mention recommend KT , they don't need to be programmed by a third party or a computer with the loaded software. They have simple user settings to make small adjustments and if someone has an issue setting them we can easily sort out most settings.
One needs to bite the bullet and buy the KT controller and display and swap them out with maybe some minor wiring .
Silvanien
Jun 5, 2024
3,539
Hi,
I took the time to think about it ! The KT controller will be compatible with the brushless motor?
I also need to find one with torque sensor instead of PAS one ! I need to look a bit more, I found this one but I have to check more precisely !
Torque sensors are shite. Get yourself a KT controller, which will give you the power you want whenever you want it.
Peter.Bridge
1,476
689
Hi,
Woosh do a bottom bracket torque sensor kit (with power based PAS levels) : it includes dual voltage controller , bottom bracket torque sensor, crankset and Display
