Alright guys. Newbie. Looking for advice for rear hub conversion for MTB
jokey67
17
You should be able to pull the frame out enough by hand to fit the motor wheel , the issue is punctures and the faff of removing the wheel when out and about. So you have two options as I see it, go tubeless a faff in it self t times setting up or use a Gaadi tube which are brilliant. A double ended tube meaning no need to ever remove the wheel.
All done mate..all worked a treat..i really hate the battery man. Horrible..road tested at 35kmh.. thanks for all the advice. Can you recommend a good battery thats not a fortune.. in terms of physical size aswell.Screenshot_20200515-190627_Gallery.jpgScreenshot_20200515-190627_Gallery.jpg
8,589
I don't know what you call not a fortune ?
You get what you pay for with cells and batteries you can opt for any cheapo battery from about £149 on ebay or go for one that costs a bit with good/v,good cells.
This 60 cell 29E should last at least 6 years and is a top cell and class leader I it's range. 2900mah 7.25a cell.
Same one as a soft pack and frame bag.
Sanyo NSX soft pack and frame bag using the hard hitting 2500mah 20a cell rated as well as the excellent/top cell in it's class the Sam 25R2r.
jokey67
17
Great pal. Ill have a look. Cheers
8,589
If you scroll down the pack sizes are there so you can see if they will fit your triangle.
8,589
jokey67
17
A sub £200 15ah battery no idea what cells are inside probably unbranded China cells or really low power branded cells.
cheers neal, good help pal.
