Ah
30,731
I thought I was being clever by saying litres ... when actually using old money is much easier.. I can visualise a gallon bucket full of Apple's. But not a watt hour of sparks. I used to use the old one bar one kw electric fire to decide how much juce things used but it's gone way past that now.
Best to just think in quantity terms, just as we do with cars, such as 30 mpg.
Average e-bike consumption is 12 W/h per mile, shown by our many surveys over the years. So if you've got a 480 W/h battery and you're an average rider in moderate territory, you can get about 40 miles range.
Strong riders and a few older weak e-bike systems can get consumption down to about 8W/h, below that it's not worth e-biking since it's mostly pedalling.
And very powerful systems can eat more, up to 20 W/h per mile or more, while you sit back enjoying the view.
Why does it have to be so complicated? It would be so much easier to give it a number! How big is your battery? It's a size 11.
That would make it much easier for everyone instead of quoting mythical range figures.
Gubbins
Ah! Just like my car then which will do 67mpg! Or so the bumf says!
Reactions: Gaz and flecc
P=VI or power=volts×amps
Unfortunately, it's not as simple as that, except that it could be used to calculate range if you knew how much power is coming out of the battery, but in most cases the power is changing all the time. In terms of the bike's power, it's power = efficiency x volts x amps. Efficiency changes all the time too, so it's very difficult to calculate anything meaningful.
Croxden
2,134
1,384
North Staffs
Croxden
2,134
1,384
North Staffs
That's right. It's how many milk bottles you can spill in there without drowning yourself.
Glad it's milk not beer bottles with your suspected gout.
30,731
Don't they measure the volume of a car boot space in litres?
Yes, it is a volume measure, but as such best suited to material that can fill a volume, such as liquid.
Boot litres were suitable when I carried bags of shingle which conformed to the space, but little use otherwise.
5,786
And then there is the vélomobile: "Due to vastly better aerodynamics of velomobiles the range of a similar electric assist unit and similar battery in a velomobile can be about 50% to 100% higher compared to upright bicycles or unfaired recumbents." (Wikipedia)
Lets say between 3.75 - 6 Wh/km (while taking things easy). By adding a bit of weight to an already heavy vehicle you do however smooth out the bumps (hills) in a ride. As there is very little aerodynamic drag to take into account the motor only has to work hard at keeping speed at 25 km.h on the hills.
basicasic
48
41
Amsterdam
I use roughly between 2.5 and 4.5 Wh per mile depending on the terrain and strength in my legs on the day and it's VERY much worth e-biking. I ride my e-bike as a normal bike and only use assistance for long or steep hills. It takes the sting out of them. On todays circuit the first bar on the power meter clicked off (ie went from 5 to 4) after 65km. Last week on the same run it was 45km.
The fact is I can ride all my routes on my normal bike easily enough but I consider cycling a leisure / pleasure activity and prefer to enjoy ALL the ride rather than most of it.
Fitter people will enjoy an e-bike as much as the less fit.
Reactions: Izzyekerslike
30,731
Yes, but as you've said, much of the time you are not e-biking, you are cycling. That's fine, but it's very far from typical.
The great bulk of e-bikers use around 12 Wh per mile as our ten years of surveying of members has shown. The ranges most quote also show that.
basicasic
48
41
Amsterdam
Well that's true enough I guess.
We are all pedaling (throttle bikes excepted) and I like to think of everyone as cycling but just with varying levels of assistance.
30,731
Agreed, but the more extreme the usage the less useful it is as information for the majority.
If you were to review an ebike and report your sort of range, virtually all those buying on the basis of your review would be seriously unhappy!
Gubbins
I was in halfords a few weeks ago and a customer asked an assistant ( young lad) how far his wife would be able to go on one.
This young lad looked perplexed so I intervened explaining that he had asked the ultimate unanswerable question and filled in with the why that is so.
He seemed quite happy with my explanation and left chewing the cud.
... I am charitably assuming that the question related to travel distance not matters romantic...
