After market bbsxx crank drive gear
5,786
There is a good reason to buy a BBS02! Just needs to be modified for trike bars...
5,786
Ultimate bbs upgrade: custom harness to interface bbs motor with standard KT controller, using standard 9 pin connector. Note wiring colours.
Some of them are hidden unfortunately... Can we have a clearer indication shot of the middle domino please?
tommie
1,760
600
Co. Down, N. Ireland, U.K.
Chain ring adapter, to 104 BCD standard 4-bolt chainrings.
http://precialps.com/uk/accessories-bafang-bbs01-bbs02/7-adapter-spider-bafang-bbs01-bbs02.html
very good quality and you can also mount a chain ring guard beside if you want.
Yes looks a good item, but at 39.00EUR ??
Same type here for £13.48
https://www.ebay.co.uk/itm/Chain-Ring-Spider-Adapter-for-8Fun-eBike-Mid-Drive-Motor-Bafang-104BCD-130BCD/352559282020?hash=item52162bb764:m:micq0PBpj-vny8scJrN0Wkw
add a 38T chainring - £22.81.
also same seller
BAFANG Mid Drive Motor BBSxx Y-Splitter 1T2 Cable Shift Gear Sensor Gearsensor
@ £16.58
All other items re Bafang BBSxx
https://www.ebay.co.uk/sch/greenergia/m.html?item=352559282020&hash=item52162bb764:m:micq0PBpj-vny8scJrN0Wkw&rt=nc&_trksid=p2047675.l2562
Deere John
532
580
47
EU
wow. Great thing. But then you loose programming capability. Is it good otherwise?
Deere John
532
580
47
EU
well. Big difference in layout. That one you put chain ring outside. On Precialps you have it on inside. As close as possible to motor. Better for chainline and if chain jumps off inwards. And you can mount a chain ring guard plate on the outside position if you want. Ie dual chain ring mounts.
I also have a cheap one on the other bike. Looks similar to your find. But I think Precialps is worth the extra cost.
Reactions: anotherkiwi
jarob10
270
83
51
Uk
Well the kt controllers hold one key advantage over standard bbs - they won’t almost immediately fail if one of the connected hall sensors (throttle, brake, speed sensor) go awry.
Reactions: Nealh
