Any advice for a person about to buy a first pedelec on Kalkhoff Agattu i8 v's KTM Macini with the Nuvinci gears? How good are the Nuvinci gears? Are they reliable?
Cheers!
Robbie
Cheers!
Robbie
You could build it into any motor, but it wouldn't make sense to do it with a crank motor. The reason for crank motors is to be able to use the gears. If the gears are already in the motor, you could drive the wheel directly.Is it possible to build a NuVinci system into a crank motor?
Not necessarily - the Shimano Alfine 11 has worked great for me and has a large gear range. Nuvinci is just another hub gear solution. I personally like having manual control of gear shifting and don't think automatic or electric gear shifting is something we all need to be talked into believing is the "right" way forward. After trying the Harmony with auto change I came back and realized I preferred what I had already.Crank drive needs the Nuvinci to overcome the high loading problems of derailleur gears and chain....
As I said, you should try one before passing judgement.Sense: the probability that you break the derailleur is very likely to be lower than that of running out of battery going up a hill, then you'll have to lug the extra 2kgs and pedal 12% harder. The NuVinci has also its points of failure like all other mechanical systems except there is little if no information about them.
