Green led usually indicates fully charged or if discharged bms not switching on. After checking the fuse if not working disconnect the bms multiwire jst and check all the parallel cell group voltages as one may be at fault, if one is too low < 3.2v or high 4.2 then your issue will lie with that group and it will need manually charging or discharging to allow balance charge to occur.
Also check charge port wire connection.
