Adjusting PAS levels of assist on Engwe EP2-Pro
8,616
They work because they are a compatable paired system .
Tyrann
Sep 4, 2024
Hey! I have the same issue as you did. Can you tell me what you ordered and the cost?
Bobbo1260
50
12
FINAL SOLUTION. After many, many months of emailing ENGWE customer support. I have finally!! received a new lcd display and controller that allows me to change the PAS levels as I require. So it is possible but you need to be very persistent with their Customer Service...
Hi paul,
I’ve read these posts with interest as I’ve not long purchased an Engwe L20SE, 250 watt and I’ve the same issue with not having an option to change the PAS power output settings. In fact there isn’t even the option to change the default 5 PAS settings to 7 or 9 levels but only managed to achieve this by following other Engwe instructions and when eventually in the 7 or 9 options the power levels are very random and there is no option so change them so it seems i need to do the same as you and change the display and controller.
If you don’t mind me asking, what was the cost of the replacement display and controller from Engwe as it seems I’ll have to do the same as Engwe have already told me my model isn’t equipped with the option of changing the PAS options, let alone the power outputs.
Thanks,
Bob.
Bobbo1260
50
12
I have am Engwe L20SE, 250 w, 36v folding step thru and that doesn’t allow the PSA percentages to be changed either.
Im not bothered about going beyond the legal 25 kph, I just want the to be able to select 7 PAS settings and equal out the power settings to get a smother transition as I work up thru the PAS settings.
I asked Engwe how this could be achieved and they told me I’d need to change the current display and controller for the previous models but they no longer have any in stock.
If anyone knows how to get round this please let me know.
