Hi guys/gals,
i have just purchased an A2B Obree, it is a non runner, the battery seems to charge and has 5 red lights when switched on but the display does not switch on, after looking deeper inside the hub, i found a traloc power dc-dc transformer with a couple of pins broke, would this stop the bike from firing up ? i think it may be for the lights ? where is the controller board located ? going to try and work backwards to determine the fault. Also when i check the output from the battery from the 2 pins, it is only showing 8v
TIA
richard
TIA
richard
