June 9, 201312 yr Hi, I'm trying to convert my 8fun kit to 48V is this possible without killing the original Controller. I think the Controller is a KU63. My Plan is to use 2 11V Laptop Battery in Parallel to give me a total capacity of10AH and wire it up in series with the Main Battery. I remember reading about this somewhere but I can't find the Thread but I think he was trying to convert to 44V if I remember correctly. Thanks in advance, Gerry
June 9, 201312 yr I think this is your missing thread: http://www.pedelecs.co.uk/forum/electric-bicycles/14618-booster-battery-experiment.html#post180687
June 9, 201312 yr KU63 controllers have 63v caps so 48v is no problem. I've run 15s lipo on one (55.5v nominal, 63v fully charged) with no issues). Obviously you'll have the wrong lvc for a 48v battery though so have a think if you need to have some other way of protecting the battery from low discharge.
June 9, 201312 yr Author I think this is your missing thread: http://www.pedelecs.co.uk/forum/electric-bicycles/14618-booster-battery-experiment.html#post180687 Yes, this is the one, thank you.
June 9, 201312 yr Author KU63 controllers have 63v caps so 48v is no problem. I've run 15s lipo on one (55.5v nominal, 63v fully charged) with no issues). Obviously you'll have the wrong lvc for a 48v battery though so have a think if you need to have some other way of protecting the battery from low discharge. I'm thinking of running an extra 11V 10AH with the original 36V 9AH Bottle Battery without a BMS on the 11V and make sure the main battery doesn't go below half charge, is this an acceptable method to protect a non BMS pack for the time being? By the way, where can I get a BMS and which one? there seems to be different types.
June 9, 201312 yr The 8Fun kit has an 8Fun controller, not a KU63. The KU63 is the one that comes from BMSBattery. You'll probably be OK with the 8Fun one, but be prepared to bu a new controller at £20 to £30. The laptop batteries should have the maH written on them. Together they need to add up to at least 8800maH. Also, you need to check the discharge rate of the cells. Some of the higher capacity ones don't have a high enough discharge rate. Most laptop batteries have a PCB inside that checks and controls temperature, discharge rate and other things. You need to bypass that because you could get the situation where one pack got shut-down by the PCB, which would then over-discharge the other one. The best solution is to break open the plastic case and remove the cells. You can then check the designation of the cells and look up their data sheet to see if they're suitable. Finally, you need to monitor the cell voltages carefully in real-time while you're riding the bike, otherwise they'll soon be scrap, which means using a lipo monitor with an extension lead so that you can see what's happening. 1S-8S RC Lipo Battery Low Voltage Alarm Buzzer Indicator Meter Checker Tester UK | eBay
June 9, 201312 yr Author The 8Fun kit has an 8Fun controller, not a KU63. The KU63 is the one that comes from BMSBattery. You'll probably be OK with the 8Fun one, but be prepared to bu a new controller at £20 to £30. The laptop batteries should have the maH written on them. Together they need to add up to at least 8800maH. Also, you need to check the discharge rate of the cells. Some of the higher capacity ones don't have a high enough discharge rate. Most laptop batteries have a PCB inside that checks and controls temperature, discharge rate and other things. You need to bypass that because you could get the situation where one pack got shut-down by the PCB, which would then over-discharge the other one. The best solution is to break open the plastic case and remove the cells. You can then check the designation of the cells and look up their data sheet to see if they're suitable. Finally, you need to monitor the cell voltages carefully in real-time while you're riding the bike, otherwise they'll soon be scrap, which means using a lipo monitor with an extension lead so that you can see what's happening. 1S-8S RC Lipo Battery Low Voltage Alarm Buzzer Indicator Meter Checker Tester UK | eBay That's interesting I thought my controller was a KU63! Thanks for that, I have opened it up and it has one large Capacitor which says 63V on it. I think what looks like a Shunt is in the middle of the board and it has 7 Mosfets. Is the KU63 OK with 48V or do I need to buy the KU65? I have dismantled the Laptop packs and removed the PCB/BMS the batts are Samsung ICR18650 26C. They are wired up 3s2p so made up 2 packs in parallel to make up the capacity to at least 10AH I now have 3s4p configuration with a balance connector but no BMS. I have a LV alarm buzzer but I'm not sure how to wire it up, it looks like the one on the link. Many Thanks, Gerry
June 9, 201312 yr Author This is the battery spec, it looks like they are not suitable and I was offering some to KirstinS who inspired me to this modification but had trouble with the booster pack. Nominal Capacity 2600mAh (0.2C, 2.75V discharge)
June 9, 201312 yr Your controller should be OK at that voltage. The KU63 and KU65 have the same ratings. The KU65 has a panel where you can get three levels of PAS, which is better than getting full PAS all the time. I think your 8Fun controller has the same panel. You don't need to get a new controller yet because your present one will probably be OK. The alarm is easy to wire: One of the end pins is 0v ( should be marked - might say "+" at the other end). The negative side of the first cell in your 3S pack goes to that first pin, then the positive side to the next pin, then the next positive, and then the final positive. Leave the other pins disconnected. Make an extension lead so that you can have the display on your handlebars.
June 9, 201312 yr The cells are good. They're for tools, electric bikes etc. You can get 5 amps max from each one, although half that would be better for them, so you need at least four in parallel (3s4p). I think the 0.2c rate you mentioned is the charge rate, so you charge the pack/strings at 2 amps. http://www.meircell.co.il/files/Samsung%20ICR18650-26C.pdf
June 9, 201312 yr Author Your controller should be OK at that voltage. The KU63 and KU65 have the same ratings. The KU65 has a panel where you can get three levels of PAS, which is better than getting full PAS all the time. I think your 8Fun controller has the same panel. You don't need to get a new controller yet because your present one will probably be OK. The alarm is easy to wire: One of the end pins is 0v ( should be marked - might say "+" at the other end). The negative side of the first cell in your 3S pack goes to that first pin, then the positive side to the next pin, then the next positive, and then the final positive. Leave the other pins disconnected. Make an extension lead so that you can have the display on your handlebars. I'll give it a go this afternoon as soon as the pack is fully charged and report back. Thanks Dave
June 9, 201312 yr Author Wowwwww....!!!! Just tried with the 11V Booster pack, I'll say this is how an E bike should perform. Initial pack voltage was 12.5V, now the reading is 12.3V and the cells were 4.15V now 4.13V hopefully I wont loose a cell or 2 tomorrow. Unfortunately, my bike computer is broken so I can't tell how fast I was going but it was a blast. I did a couple of hills with no problems the cells never went below 4Volts and no overheating. I will be doing a 12mile commute tomorrow and I'll let you know how I get on. Cheers, Gerry
June 9, 201312 yr Could you take some photos to explain how you wired it because I think other people are interested in how to do it.
June 10, 201312 yr Author Could you take some photos to explain how you wired it because I think other people are interested in how to do it. Will take some photos when I get home.
June 10, 201312 yr Author Today's commute was 12miles. initial booster pack voltage was 12.3 and the lowest cell was 4.03. Now, they are 12.0V and 4.0V respectively. I currently have no pedal sensor so this is purely throttle only. Again no overheating and no loss of power. I'll see if it will do another 12 miles this evening if not I'll increase the capacity ti 12.5AH I have set the buzzer to 3.4V is this OK? Thanks, Gerry
June 10, 201312 yr 3.4v is OK. Until you recognise the voltage behaviour of the booster pack, just keep an eye on the voltage monitor, After a few charge cycles, you'll know what they do. I wouldn't rely on the beeping alarm.
June 11, 201312 yr Author Will take some photos when I get home. I will upload some pics later, my Camera is misbehaving at the moment. This is what I did 11V 56WH Laptop Battery 2X from a Junk Laptop Imax B6AC Charger 1X Amazon £27 Multimeter 1-8S Voltage buzzer £3.00 3S Balance Leads 1X 99p 16Amp Wires Blk and Red Soldering Iron Heatshrink sleeves 99p Bullet Connectors Electrical Tape Screw Driver Scissors Side Cutters Open the Laptop Battery pack carefully using a screw driver and pry gently Disconnect the BMS PCB, be careful when cutting the wires watch out things can short out. Use a Voltmeter and locate the 0V and +11.1V this should read at least 12V if the battery has been pre-charged Locate the +3.7 V and the +7.2V 0V +3.7V +7.2V +11.1V These batteries are Samsung 2600mAH and the are configured as 3S2P this is an 11V 5.2AH Battery pack. To make at least 11.1V 10AH pack I connected 2 packs in parallel using 16Amp wires I also added the 3S balance wire, see url R/C Calculations. I also added a Voltage monitor as advised by D8veh as I don't have a BMS. I have soldered all the connections as above and charged the pack at 2.5Amps (not sure if I can increase the charge rate) I connected the pack in series with the 36V Bottle battery and connected the voltage monitor so that I can see if the cells are OK I have done a 24mile return commute today on throttle only and it has performed well, I am very happy. Thanks to D8veh and the others who helped me with this project.
June 11, 201312 yr Thanks for that nice explanation. When I broke up my laptop batteries, it was very difficult to break open the case. 2.5aH is OK as a charge rate, but don't go any higher. The recommended rare is 0.2c, which would be 2amps, but many ebikes charge the same cells in 10s4p configuration at 2.5amps. For anybody else interested in doing this, which works on virtually any bike with hub-motor, you can get job-lots of used laptop batteries from Ebay, or try your local recycling centre. Wghen I got some, virtually all the cells were good, but you need to test them. The Imax charger can do a discharge test as well as charge, to verify them. http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR0.TRC0&_nkw=job+laptop+batteries&_sacat=0&_from=R40
June 11, 201312 yr Author Here are the Pictures. [ATTACH]6067.vB[/ATTACH] I used a screw driver to open the pack very carefully and pry gently. [ATTACH]6068.vB[/ATTACH] I carefully separated the PCB/bms by cutting all the wires [ATTACH]6069.vB[/ATTACH] I checked the voltages where the wires were so I can connect the Lipo balance wire and the output wires. [ATTACH]6070.vB[/ATTACH][ATTACH]6071.vB[/ATTACH] Here is what I made earlier with all the wires soldered. I hope it all make sense but have a look at this URL on how to connect the balance wires R/C Calculations [ATTACH]6072.vB[/ATTACH][ATTACH]6073.vB[/ATTACH][ATTACH]6074.vB[/ATTACH][ATTACH]6075.vB[/ATTACH] This is the original Battery connection to the Controller [ATTACH]6076.vB[/ATTACH] I then cut this wire and inserted the 11V Booster pack in series.[ATTACH]6077.vB[/ATTACH][ATTACH]6078.vB[/ATTACH][ATTACH]6079.vB[/ATTACH] Here is the finished product. Well not quite I plan to put everything in a bag on a pannier rack. [ATTACH]6080.vB[/ATTACH][ATTACH]6081.vB[/ATTACH] Cheers, G
June 11, 201312 yr Author Quick question, what happens when the bike is travelling more than the maximum speed of the Motor, does it take current from the batts? Im just wondering because I did around 50 miles before I added the 11V Booster. Most people say a 36V 10AH range is only around 25miles, bearing in mind I m using throttle only and will sometimes push and leave the throttle on max even when I was travelling at more than 15mph.
June 11, 201312 yr With only the normal battery, the maximum speed is about 15mph. Once you get past 12 mph, the current reduces in a ramp down to zero amps at its maximum no-load speed of about 17mph. At that speed, the motor is still spinning, but virtually no current is drawn, so, in that respect, the faster you go, the further you can go.. When you add the booster pack, the whole power curve moves up the speed range, so that you'll be drawing significant current at 17mph. Now you have to pedal at 20mph to reduce it close to zero, so you're likely to use a lot more wHs, even if you go at the same speed, but you have 30% more battery to compensate. If you use the PAS sensor at level one, it shifts the power curve back down, so you'll get a lot more range.
June 11, 201312 yr Author With only the normal battery, the maximum speed is about 15mph. Once you get past 12 mph, the current reduces in a ramp down to zero amps at its maximum no-load speed of about 17mph. At that speed, the motor is still spinning, but virtually no current is drawn, so, in that respect, the faster you go, the further you can go.. When you add the booster pack, the whole power curve moves up the speed range, so that you'll be drawing significant current at 17mph. Now you have to pedal at 20mph to reduce it close to zero, so you're likely to use a lot more wHs, even if you go at the same speed, but you have 30% more battery to compensate. If you use the PAS sensor at level one, it shifts the power curve back down, so you'll get a lot more range. Thanks d8veh, that explains it. Now with the Booster pack, what I have noticed is that if the Main Battery pack is not fully charged it seems to take it out on the Booster. Today, on the 3rd 12mile commute my main batt is only 1/4 maybe 1/3 charged as there is only one green light and the booster I charged last night this is the 1st time the voltage dropped below 12V and the cells at around 3.9V. Perhaps I should make my Booster a little beefier and add another 3s2p? Is this an overkill?
June 11, 201312 yr The cells in both batteries are 4,2v fully charged. They soon drop down to 4v when you start riding. They gradually go down to about 3.6v, but then start to descend increasingly more rapidly, so at 3.9v, they've got a long way to go. They're only about 25% of the way down in my reckoning.
June 11, 201312 yr Author The cells in both batteries are 4,2v fully charged. They soon drop down to 4v when you start riding. They gradually go down to about 3.6v, but then start to descend increasingly more rapidly, so at 3.9v, they've got a long way to go. They're only about 25% of the way down in my reckoning. I'm panicking over nothing really as soon as I see anything under 4V I start thinking about recharging. Where can I get a BMS for this? I had a look at BMS battery.com and they have 3 different types. Can I use the original Laptop BMS or is this too optimistic? Cheers, G
June 11, 201312 yr The original laptop BMSs are not simple. They often store data about the battery, and can do nasty things like switch off after a certain number of charges or after a certain time,so I wouldn't recommend it. As long as you always fully charge both batteries together, you should never have to worry about your booster pack as long as it has more amp-hours than your main one. You can do a simple test: Fully charge both batteries; connect them together and use them for about 25 miles or more (keeping an eye on the booster pack cell voltages; let them settle for 15 minutes or so after the ride; measure the main pack and divide by ten = individual cell voltage; measure the cell voltages of the booster pack; if they're higher than the main pack you can probably forget about monitoring them in the future, but of course, one day you might not charge them properly, so it's always good to have the alarm fitted.
