I did clock that one when they first came out.
Yes - that Samsung is a 500 cycle pack too, not a long life 1,000+ cycle pack like you get supplied on higher end retail bikes. Makes it equivalent of about £1,400 shipped taking cycle life into account - which is an astronomic amount for a battery pack - especially since the bikes it'll be suitable for at 50V are likely to be pretty power hungry. I like the precharge tho'. Saves making one.I did clock that one when they first came out.
Nice pack, but would be very expensive at around £700 shipped.
I'm hoping that a manufacturer will start making the hardcase packs that attach to the water bottle holder. Similar to the Bosch ones, rectangular or triangular but not cylindrical.
£520 shippedNice pack, but would be very expensive at around £700 shipped.
That's 500 cycles at max charge voltage and max discharge. Charge to 90% and only do 80% dod's and you'll see 1000 cycles easy.Yes - that Samsung is a 500 cycle pack too, not a long life 1,000+ cycle pack like you get supplied on higher end retail bikes.
How does that work then ? Always get completely bamboozled with all this battery thing. I understood you had to manage charging of LiPos, not charge 100% and cut them out before they lose too much charge - but isn't this a Li-Ion battery ? Everything one reads about them suggests they like to be kept topped up.That's 500 cycles at max charge voltage and max discharge. Charge to 90% and only do 80% dod's and you'll see 1000 cycles easy.
Don't forget the dreaded import tax on top of that£520 shipped
Li-ion/lipo are the same chemistry - the distinction is just the solvent - liquid on a li-ion battery and a solid (polymer) on the lipo.How does that work then ? Always get completely bamboozled with all this battery thing. I understood you had to manage charging of LiPos, not charge 100% and cut them out before they lose too much charge - but isn't this a Li-Ion battery ? Everything one reads about them suggests they like to be kept topped up.
What's "dod" ?
Oh yeah :-(Don't forget the dreaded import tax on top of that
OK. So with regard to the question, why the different advice regarding management to Lithium Ion and Lithium Ion Polymer batteries especially viz topping up ?Li-ion/lipo are the same chemistry - the distinction is just the solvent - liquid on a li-ion battery and a solid (polymer) on the lipo.
In fact the correct names are Lithium Ion and Lithium Ion Polymer.
Quite a few li-ion batteries with BMS's - Bosch included - only charge to 4.15v per cell and limit depth of discharge to 80% - which is why they can boast high cycles.OK. So with regard to the question, why the different advice regarding management to Lithium Ion and Lithium Ion Polymer batteries especially viz topping up ?
Does the Li-Ion BMS on high stated charge cycle batteries see to the top charge capping and dod limiting so as to achieve those results ?
Sadly it would seem that the days are gone when Shemozzle could supply good and decent British citizens with high tech, cutting edge Chinese e-bike solutions and reluctantly we must return to the old windscreen wiper bldcm's and Archimedes Screws of yore.Hi hech,
Just the clear up the impression that you have that I will be selling these, I am afraid that won't be the case. My days are over for generating hard earned revenue for the mafia protection rackets for UK plc, especially now, as I can see how they squander it so easily.
I have, over time, purchased various items from a reliable seller on aliexpress and contacted them to see if they can supply the 8fun once I saw it on alibaba.
They are seeing if they can deal direct with the supplier and provide small quantities, whereas alibaba is really for trade only.
If anyone has a serious intention in purchasing one then let me know and I will give you a link, as soon as they can confirm availability, firm price and delivery charges.
If they decide to list it as a product on their site then you will be able to go direct.
What I am trying to avoid is time wasters and loading them up with bogus inquiries.
To be honest the crank drive doesn't appeal to me but I can see the advantages for certain user requirements.
Shame that. Thing is both Bosch and Impulse use 3 separate sensors (cadence, torque and speed) to detect what the rider is doing and offer assistance appropriately... to varying degrees of success for an individual rider depending on how the software is programmed to respond. The Chinese seem to be a way away from this and that's the reason I don't think they can supply competing crank drive bikes... they haven't yet got the hang of one set of inputs yet let alone 3.Unfortunately, also, from my tests, it appears that all the new Chinese torque sensor bikes are using the sensor as a switch for the
normal controllers, not as a proportional torque device; however the penny has now dropped, so we'll have to wait a bit longer before we get a Chinese bike that behaves like a Bosch.
