Very frustrating that you don't give the information that I require.
Put the charger away. Measure the voltage across the two thick wires that come from the cell-pack. Then measure between the cell-pack ground and each of the pins on the multi-pin connector.
If you already did that, your battery is totally knackered, which would be very unusual, seeing as it's protected by a BMS. It's not uncommon to get a few bad cells, but I don't think I've ever seen one that bad, which makes me suspicious about the measurements.
