Hi all,
Hope someone can help me with a pedal assist connectivity issue
Please see attached the 3 pictures to help assess my problem!
I have a kt controller 48v 40amp controller.
Firstly is the 3 wires (red white and black) jst connector the pedal assist cable? if so i have two possible options for connectivity.
Option 1
Make an adapter cable
Option 2
Take the controller apart an resolder the 3pin ip65 yellow warerproof connector direct to the circuit board. If so what wires need to be soldered to board?
Any help would be appreciated if someone has had the same issue!
Is there also a setting i need to enable on my lcd3 display to activate pedal assist as i have tried all combinations with the wires to initiate the motor when i rotate the pedal and all trials have failed so far in enabling the pedal assist!
cheers
phil
Option 1
Option 2
cheers
phil
