£1700 all but a pound, that's more than the wisper torque and the juicy roller albeit the two latter are hub drive, can't wait to ride these.Hi Andy, yes they all do at the moment.
All the best, David
All the best, David
That's not right. Freego have two versions of the same bike. One is a stepthrough. Their listings are a bit confusing. I had to look twice. I know they do one because it's in our local shop.Thanks again Andy88, I had a look online at the Freego Bafang Max Drive and also the Bottecchia versions, but they were based on a reg MTB top bar frame.
I'm surprised your ride hasn't been reported by the Strava mafia! They are on to me within minutes if I post any electric bike times there - ie significantly faster than my usual attempts!This should be of interest, here's some Strava stats comparing the development Juicy bike with the Roller motor system compared to my old classic Bosch bike.
I did my first run on the Juicy,and second run back up on my bike, despite being tired from the first run I was 2:24 faster on my bike, I didn't find the Juicy bike enjoyable to ride in the way my bike is.
https://www.strava.com/activities/565062132
Yes it's listed as an E-bike ride, so the segments you see are made by me for e-bike riders.I'm surprised your ride hasn't been reported by the Strava mafia! They are on to me within minutes if I post any electric bike times there - ie significantly faster than my usual attempts!
Although looking again I notice these segments have only been ridden by a couple of people.
What I don't understand though is what you do when you ride over a segment which is not one of your own? Is there some way of marking a ride so it doesn't show up on all the segments you ride over? I've given up putting GPS records of ebike rides there - I just put the time and distance so its at least included in my annual totals etc.Yes it's listed as an E-bike ride, so the segments you see are made by me for e-bike riders.
Listing as a normal ride looks like this![]()
When you upload your ride in the drop down activity box choose e-bike ride rather than ride, then it will be correctly listed and won't trigger the normal ride segmentsWhat I don't understand though is what you do when you ride over a segment which is not one of your own? Is there some way of marking a ride so it doesn't show up on all the segments you ride over? I've given up putting GPS records of ebike rides there - I just put the time and distance so its at least included in my annual totals etc.
Excellent, thank you, I haven't seen that option before - maybe its newish. Wish I hadn't deleted those rides now - maybe I still have them on Garmin Connect and can restore them.When you upload your ride in the drop down activity box choose e-bike ride rather than ride, then it will be correctly listed and won't trigger the normal ride segments![]()
If you look at my Strava you'll see nearly all my cycling is e-bike, and the cycling totals still work.
Can you guys tell me how easy it is changing gear and maintaining derailleur gears? Looking at IGH but so restrictive on bike choice, looking to convert to BBS02 or BPM. Is Deore the best? Easiest?Excellent, thank you, I haven't seen that option before - maybe its newish. Wish I hadn't deleted those rides now - maybe I still have them on Garmin Connect and can restore them.
I forget how long the e-bike category has been there now, a year or so? perhaps Phill can remember.Excellent, thank you, I haven't seen that option before - maybe its newish. Wish I hadn't deleted those rides now - maybe I still have them on Garmin Connect and can restore them.
It's debatable Andy, which model of derailleur is best but I know many bikes, both manually-powered and electric, make do with gearsets from the lower reaches of Shimano's range and present few problems. Frankly, you probably wouldn't gain a great deal by ignoring the budget end in favour of the high-end products but your wallet would be considerably lighter.Can you guys tell me how easy it is changing gear and maintaining derailleur gears? Looking at IGH but so restrictive on bike choice, looking to convert to BBS02 or BPM. Is Deore the best? Easiest?
