2.4 " off road tyres
Need some "bike park Tyres" good grip for trails, climbing, risking my life down hill and plugging through mud etc etc.
Looking around are 2.4" any good as the extra volume with a hardtail is very attractive.
Also do they fit well in a Haibike 29
Well I think the sausage inner tube is off the shopping list. £££££
I need a set of specialist tyres to join Chris at Hopton Woods and Forest of Dean etc. to have a different riding experience.
Great fun can be had when you have great grip.
Having a ride on Chris's full seven while he rode mine, was a valuable experience for both of us.
The rapid Robs I had on were worn out and not up to the conditions, I am looking for some specialist tyres to use when going to tracks then change back to my more flexible tyre after.
The balloon effect of a larger tyre is attractive.
As I only have the hardnine I need to help it out as much as possible.
Perhaps go for the same tyre choice as Chris is using.
Also check that you have enough chainstay clearance before making you final choice.
Those Magic Mary's always get a good write up. When time comes, I'd replace with them? Although the knarly downhillers at the Black Mountain C C said Maxxxis were the best. I don't know which ones?
Lot's of good advise given here Chris, so can't really go wrong as a starter. Either way you will either be happy with your choice or like most of us changes tyres over the years until you decide which you prefer. Much is personal choice.
Remember more choice leads to more confusion (marketing speak), and you can apply this to advise etc.
I will second Eddie's advice about checking clearance.
The latest 2" and wider tyres are big in all directions and may not fit every 29er frame or fork.
Quite commonly bike makers put a 29er fork with 650b/27.5 mountain bike tyres, and even then there's not loads of clearance.
Magic Mary is a bit cheaper here, even with some postage.
https://www.bike-discount.de/en/buy/schwalbe-magic-mary-snakeskin-trailstar-29x2%2C35-tl-easy-folding-230917?currency=3&delivery_country=190
I have Magic Mary's on mine, but it's only a 27.5. Can't fault them and I have tried most sorts of tyres. I'll be buying these again such was the transformation in the bike. Have gone tubeless also, running 24psi.
It's a minefield so; I have ordered a pair of Smart Sams with green guard and a Magic Mary super gravity.
Punctures spoil enjoyment, hopefully these should resist as good as any. I am sticking with tubes with slime in as it's easier for me to swap tyres.
Going to run with the Smart Sams for general use and fit the Magic Mary on the front when I go playing with Chris.
I will let you know how it goes.
Good choice. The best tyre by far, for puncture resistance are marathons mtb, but i found they were too big a compromise vs grip etc.
The second best for punter resistance are smart sams with guard, but they still puncture now and again compared with marathons.
Interesting to see the difference between the Marathon MTB and Smart Sam.
Maybe summer/winter choice.
Just have to see how much drag there is with the Magic Mary?
Ideal set up would be a spare set of rims !
https://www.schwalbe.com/gb/offroad-reader/magic-mary.html
i have a sg hans damp on my rear as have ripped a normal one off the rim 2 times as the walls are very thin.
it is a fkn mission to fit the sg ones tho :)
I bought the Magic Mary after your recommendation, thanks.
I looked at the prices and then thought how much would you give not to have a puncture.
I look forward to the fitting process then !
just make sure it is the right way round as only rolls one way direction wise.
and if any one is about take cover as can fling a tyre lever 10m if you dont snap it in half.
take it to halfords and get them to fit it, will be the best 5 quid you even spent watching them try fit one of them pmsl.:)
Tons of grip arrived !!
Tomorrow morning, after taking the dog do I fit the Magic Mary to the front to give it a try, or fit the two Smart Sams and be sensible for a bit. I think I have to try the Magic !20170303_220048.thumb.jpg.66acd74cc902ab00330d33c51728837d.jpg
Really ?
Thought you put the grip on the front.
That is why I only bought one, to have grip on the front and a faster tyre on the back ?
So I was going to leave the Smart Sam on the back.
Not that I know anything at all about it as this is new to me.
Really ?
Grip at the front, traction at the back.
But only if you accept there's much of a difference between the two.
Some mountain bikers fit the rear tyre 'reversed' - against the rotation arrow on the sidewall - because a V-shaped tread in that configuration will supposedly give more traction.
