What would you do re brake cutoff if the bike had hydraulic brakes? https://bmsbattery.com/ebike-parts/459-hwbs-hidden-wire-brake-sensor-1pcs-parts.html is for cable only it seems.
Town, country or city riding makes no difference. You have complete control of the motor. it goes when you pedal and stops when you don't. Those expensive Bosch, Yamaha, Shimano and Brose bikes don't have brake sensors.Admire your confidence in it behaving but in city riding would you brave it without?
Thanks d8veh. Have you fitted any of the 14.5Ah Whale packs yet from eclipse?battery from eclipse. i prefer this type of battery because the mounting points are more likely to line up and it fits to the frame better. i always add a third rivnut for security:
http://eclipsebikes.com/product_info.php?products_id=104
It's 23 miles from my home to the office the ebike calc says this will use 95% of the 12ah battery when running 500w motor in one direction with 100W input from myself so a charge at work is necessary regardless. I'm 6ft 7in and 20 stone so a big fat wind breaker. Unless the real world range of a similar spec is much greater than the theoretical figures show?A charger only costs £20, so keep one at work for the windy days.
