Brilliant thankyiuBeautiful bikes, those Hummers. Can't beat a good ti hard tail.
You're going to be looking at something older or on clearance to get 26" and straight steerer.
I'd recommend something like the Rockshox Reba. Great fork, and you can find some bargains around on ebay, or in the clearance sections of some of the on-line guys.
If you see or have anything please do let me know. Initial searches are all taperedBeautiful bikes, those Hummers. Can't beat a good ti hard tail.
I wouldn't recommend Fox Floats, for a number of reasons, they seen to take quite a bit of looking after compared to the basic rockshox. They are also bolt though axle, so might be an issue, and 140mm is a bit more than a ti hard tail is really designed to work at its best with.
Are you going to use it on-road or proper off-road? Why not go with 100 mm.? That'll give you a lot more choice.I have just obtained a Cove Hummer 2010 titanium hardtail frame ! Very exciting stuff
It takes a 120mm straight steer front fork.
What would you recommend for light XC use for under 150 quid?
It's going to get used for xc on South Downs and on roadAre you going to use it on-road or proper off-road? Why not go with 100 mm.? That'll give you a lot more choice.
