Hi all,
Questions at the bottom for those with little time.
I had a bad spill a few weeks ago - smashed my collarbone into multiple pieces, and have been laid up recovering for several weeks. Unfortunately my lovely wife has therefore decided that cycling is dangerous. I'm considering using it as an excuse to get a recumbent trike, and if so, options for adding a crank drive motor to it in the cheapest manner possible.
I currently have an 8fun/Bafang 500W CST hub motor, which I've been running for the last 1500 miles without problems (apart from me coming off!)
I was therefore wondering if I could use this, in conjunction with a freewheel crank and suitable mounting brackets to drive the front crank.
1. Is this possible?
2. Does the whole hub rotate, or does the mounting bracket have to be fabricated to use the spoke holes to force it to be stationary?
3. Or is it more sensible to just sell the CST motor and controller, and buy something like the Bafang BBS 01/02? I want to keep the front derailleur so understand this would require some work to modify the BBS unit.
4. Any other better ideas on how to add a mid drive motor to a recumbent trike?
Many thanks
Phil
Many thanks
Phil
