TSDZ2B Bits and Pieces
Az.
1,320
594
Plymouth
I am just installing TSDZ2B and trying to find all bits that were flying around for few months. I just wonder if I really need all of them or if I can just happily skip some.
For sure I won't be installing rear bracket as there is no space for it and I don't think it is needed:
57446
Real question is if I really need this bit:
57447
Leaving it behind would make cable management much easier. In practice it would mean whole motor would be held in place only by this:
57448
I have installed motor in a way it should not rotate even without additional supports.
16,498
You don't need to install the anti torque bolt and bracket. The V shaped bracket has splines. Make sure that the splines are facing the bottom bracket shell.
Reactions: Bikes4two
16,498
You have to install the V shaped bracket in picture 2. The anti torque bracket in picture 1 is optional.
16,498
Best to download the manual from the tsdz2 webpage. The V shaped bracket is part of the bottom bracket assembly. You have to fit it.
Bikes4two
900
401
Havant
Why? The only reason to install it IMO is to prevent motor rotation, ergo I don't need it in my case. Is there something I don't see?
Without fitting the grooved 'vee' bracket in yr pic 2, the motor would rotate in the bottom bracket shell, or at least it would in 'normal' bikes.
You say "..... not in my case" - why is that then?
Pic courtesy of @Woosh TSDZ2 installation manual.
57455
Az.
1,320
594
Plymouth
It is working! It is working! Oh, I really like the feel... but I miss throttle. Luckily bike is for my wife, not for me.
Now the hard part - cable management. Should have really started with that and prepared some intube cables to solder after motor installation. It is to late now to make it really tidy, but I was eager to test it out and :(
To install motor I had to remove a bit of frame around bottom bracket. I took time and now motor fits perfectly well - it won't rotate even 1mm.
Reactions: Bikes4two and Woosh
tonyw
34
15
If the motor is being pressed against the frame by the motor torque, then I think the danger is that motor casing cracks, which is what happened to a friend's bike.
Reactions: Az.
Az.
1,320
594
Plymouth
Hmmm... that is a good point.... Do you know what was motor rated power?
3,012
Perhaps the case would be less likely to crack, if the force was spread over a larger area of motor case? Shape some sufficiently thick metal to fit around part of the case, to place between the frame and case, so force isn't acting on a small contact area?
matthewslack
1,632
1,207
The bit in post #7 is essential. Without it the motor is only supported at one end, and the metal at that end will have bending loads applied to it that it has not been designed to survive.
Any distortion of the casing will compromise gears and bearings even before any cracking and falling off.
It sounds like you found space for it, so no issue hopefully!
3,012
@Az. - Do you have photos? Personally, I would have bought a different bike to convert, rather than remove a bit of bike frame.
Az.
1,320
594
Plymouth
That is another very good point. It looks like I will have to remove motor after all and start from scratch...
On another hand I am tempted to take a risk, leave things as they are and move on to what is really interesting - my MTB and TSDZ8.
Yesterday I took new bike and my kids for a short test ride (+-30km) and all worked well.
Az.
1,320
594
Plymouth
OK, I will take photos.
Bike is great and it will stay (Cannondale Adventure EQ https://www.tredz.co.uk/.Cannondale-Adventure-EQ-2023-Hybrid-Classic-Bike_244627.htm ). Only question is how to convert it. Worst case scenario I might need to install rear hub, but I think TSDZ2B should do just fine.
Don't worry about frame I removed only a little and mostly non structural fragments.
3,012
My concern would have been reduction in resale value. The potential for a cracked motor case wouldn't have crossed my mind, because I've never heard of a Bafang motor case cracking. Cracked TSDZ2 motor cases have been mentioned on the forum before.
Peter.Bridge
705
324
I was thinking about a TSDZ8 conversion. If I was looking for a donor bike, is there anything I need to look out for to make the conversion as simple as possible ?
1) BSA bottom bracket (or press fit BB that I can buy BSA adapter)
2) Space on the downtube for battery
3) Hydraulic brakes
4) Anything I need to be wary about with regards to rear brake and gear cabling routing ?
5) Is there something I can check on the potential donor bike regarding the motor rubbing - or is that easy to fix ?
6) If I choose a full suspension donor bike is there anything I need to be careful of ?
Az.
1,320
594
Plymouth
3) Hydraulic brakes
Hi Peter
My main consideration would be space for battery. Especially if you plan to buy full suspension bike. Smallest Hailong battery is "Pro" I think - 93mm/368mm/90mm.
Hydraulic brakes are a must IMO, but donor bike can have mechanical as change to hydraulics is very easy as long as frame has mounts.
Brake and gear cables are problematic when you install TSDZ2B, but you will find a way around this problem. Not sure about TSDZ8 just yet. I will let you now.
Reactions: Peter.Bridge
Peter.Bridge
705
324
Hi Peter
Thanks Az
I think I have found the answer to point 5
"5) Is there something I can check on the potential donor bike regarding the motor rubbing - or is that easy to fix ?"
"c) Bikes with fatter tyres such as modern mountain bikes tend to have a flared chainstay which will obstruct the motor from fitting. What this means is the horizontal tubing flares out very quickly from the bottom bracket as it goes to the back axle. Place your eye on the seat and look down to the pedals and observe how far the largest chain ring goes back. If the metal tubing going back towards the rear axle flares out much before this point the motor will probably not fit. See pic below for one that was a little tight.
57496
16,498
The tsdz8 has a very similar size and shape as the bbs01b, much easier to fit than tsdz2b, especially if you have cables running under the bottom bracket. You would need to reroute cables to fit tsdz2b, not with the tsdz8.
