Received my new sensorless controller today, from e-crazyman.
Took 11 days from order to door, so not bad considering it came from China.
Removed old controller and battery docking plate from bike, which gave me some space to hide the wiring loom.
Pretty straight forward swap, apart from the following:
How does it run?
Wow, I've heard horror stories on how naff sensorless controllers are to run.
Well I can say with confidence, that this little beauty runs sweet as a nut.
Smooth, progressive pull from standstill, and none of that stuttering I heard so much about.
The controller is rated at 25A, and it shows. The pull is so much stronger than the stock, shunt modded controller.
No idea what effect this will have on battery life or range, but hey, I'm having too much fun to worry
I'll probably stick with sensorless in the future, as there's no hall sensor failures to worry about.
Beastamatic is back and he's angry
The battery connector on the controller needed to be cut off. It has a neg and a pos wire, but also another smaller pos wire. I needed to solder the smaller wire to the main pos wire, as this is meant to be attached to a switch. The battery has a key switch, so I didn't need this function.
I found that although the motor wiring had the same 3 colours, red, green and yellow, the yellow and blue wires needed to be swapped. Otherwise the motor refused to run.
The bike's brake cut-offs have 2 individual connectors from each brake. The controller only has one cut-off connector. I therefore parallelled the brake lever wire together, and wired it into the one connector on the controller. Still works the same as original set-up.
How does it run?
