Started fitting e bike kit and on fitting have come across a couple of issues the main one being the throttle is not working, When the throttle is activated the LCD shows a revolving symbol but there is no power to the hub. Also one of the HWBS sensors is not working properly. Both sensors show a red LED when activated, but only one shows on the LCD when activated. Therefore when the motor is running only one sensor will stop the motor. I have tried swapping the connections around, but this does not make the other sensor work. Therefore it seems like a faulty sensor. Have taken photos of throttle turned and what the LCD display is showing and LCD display without the throttle used or turned it shows in the far right corner of the display the current temperature, could there possibly be a fault with the controller ? appreciated your guy's help on this one...
