Hi again. d8veh is right. yet as he say, the jumper points might still be there, just not labeled., Can't see any jumper wiring, but if there where, that would be the point, so stretching the side plate further out on the wire to get room to examine further would be good (though be very gentle, especially the first time, since they are glued/silicon'd together with the rubber surroundings)..
Don't know what Connector 6 is supposed to do, but I would try !! AT YOUR OWN RISK !! to disconnect it and power up (due to my trial and error nature, but can't see how that should blow anything up
.. did a fast google search on your version of the board, but couldn't find anything in a hurry.
<edit>
I now see that you have a throtle walking pedal override that limits to 6km/h.. could this curcuit give you any hints to how the limiter works? This might be a "golden plate" in this regard.. !
I see some more tonight when I get some nerding time ;D
I also have a wiring diagram of the whole card layouts of all models, I just need to figure out where I put it
Then I can compare it with mine, to figure out if, and if so, where the enactmen pins are
Don't give up on it yet
Another thing to try, though a bit of a stretch, is to short every solder point fairly close together on the board (one at a time) (WHILE BATTERY NOT CONNECTED), since some jumpers tend to erase some information in memory, so the power is not actually needed for the change. If you are lucky, that would trigger off the limiter upon next bootup. But as I say, this is stretching science a bit, and you are now entering the world of real old school hacking
hehe
I also would suspect such a circuit to need some sort off battery(?) which I cannot see on this boards
but hey, I have seen stranger things working than that
-Kaare
