New Ebike shaft drive system
16,507
frames for shaft drives are easy. You only have to replace the bottom bracket shell and the drive side chain stay.
The same article mentioned a mini hub motor, 1.4kg - sounds just the right kind of weight for next year bikes.
Reactions: VictoryV and IR772
grldtnr
627
288
south east Essex
Shaft drives for pedal cycles are nothing new, in fact ,most new things are really updated and refined ideas,...but getting back to shaft drives,for unpowered bikes they are inefficient, they might be useful for cargo box trikes and long cargo bikes, the problem is restricted gearing, i.e. you can't gear them high enough without bulky and heavy gearboxes.
30,416
grldtnr's answer in the above post got lost inside the quote, here it is below:
"Shaft drives for pedal cycles are nothing new, in fact ,most new things are really updated and refined ideas,...but getting back to shaft drives,for unpowered bikes they are inefficient, they might be useful for cargo box trikes and long cargo bikes, the problem is restricted gearing, i.e. you can't gear them high enough without bulky and heavy gearboxes."
Reactions: Teesebike
Kenny
383
111
West of Scotland
Having owned a few shaft drive motorbikes (that's my Yamaha XJ750 in my avatar). I think shaft drive would go well with electric bikes.
The efficiency loss not such an issue and there nice and clean with low maintenance.
The forthcoming mini hub motor mentioned in the article is even more welcome for me. All the UK kit suppliers seem to supply lardy hub motors of 3 - 4 kg even though excellent lightweight motors like the Q100 have been around for ages.
Hopefully this mini Bafang will be a good un and available in the UK in time.
KirstinS
3,224
899
Brighton
A decent reliable mini hub would be great. Tongxin to fragile, keyde seem also unreliable and expensive, the mini crank from gng is untested and stupidly pricey
There are the cute motors and , from memory, either the q75 or 85 is only 1.6kg but still bafang know how and reliability (usually) is very interesting to me. My titanium road bike remains unconverted. Partly cos I'm training for a mtb xc 24 hour endurance race....and partly as I've not really got an option for super light conversion that I happy to spend money on. This mini hub may be it
Warwick
731
225
Warwick
Zerocycles - now long gone - sold shaft-driven, unpowered bikes a few years back, but they didn't catch on.
Peter Thornton
104
67
72
Kendal
The Paris bikes didn't seem to take much power from the shaft drive, I suspect the gearing problem is the big issue, I think they had just three gears.
30,416
A limited gear choice was also the Zerocycles problem, in their case only the old Shimano 7 speed hub gear but not the newer 8 speed ones. It's that sort of inflexibility that limits shaft drive adoption. Their designers should offer versions for all the best hub gears, Shimano 8 and 11 speed and the Rohloff 14 speed.
5,785
The Bafang shaft drive plugs into a Shimano gear hub. The marketing blurb says it is for the rental bike market which makes sense.
