My Cargo bike build.
8,253
I won't touch the OSF if I don't see 5v.
Yes stock firmware files are saved.
Bikes4two
903
403
Havant
Tomorrow will be an attempt to upload the new emmebrusa firmware v.20.1C. 2 version.
But first I will have to 100% test that the controller is the old version and not the new one. Physically looking at the pcb it looks like the old type, by metering between Gnd & swim one should see 5v. The new versions shows 0v.
Neal,
  • Isn't v20.1c.2 still in pre-relaes/beta? 1c.1 has been around for some time and thus tried and tested.
  • Each to their own of course but if I were on my first build, I'd not be brave enough to try a pre-release version 'cos if something didn't go as planned I'd wonder if it were me/my motor rather than a potential firmware issue
8,253
v20.1c.2 is now the default version on git hub, it has been fully released.
I have the old controller 4.75v seen gnd- swim.
Reactions: Bikes4two
8,253
I'm a bit stuck now as not sure how to open the java configurator to down load the OSF. I think I'm missing a programme in W10 to allow me to open the Java configurator file.
3,027
Sorry Nealh but I have no idea about the process of updating firmware on the TDZ2, because I don't of course have one and thus haven't looked too closely at the process. I also refuse to install Windows 10 no matter what! But it looks as though you have to download a .hex file, configure STVP and use STVP to flash your controller with the .hex file. STVP should be somewhere on your computer? It's in this vid:
3,027
STVP is an .exe file and might not need JAVA, unless it's calling on JAVA libraries - but if it does need JAVA library functions in order to work, you can download JAVA if Windows 10 doesn't already have it:
3,027
...sorry, this is the next vid, which isn't about flashing the controller either:
3,027
Man, this is a long process... here's the next one - he does flash the controller in this one and encounters problems before succeeding:
3,027
If you mean load the .hex file into STVP, it's a STVP function. If you mean download the OSF .hex file from the website to load into STVP later, that's probably right-click and "Save as", otherwise windows likely won't know what to do with a .hex file, or it might open it in a .hex file editor if you have one installed. I'd definitely avoid editing that .hex file! :eek:
8,253
The file I can't open is the java configurator that allows the OSF to load as far as I'm aware.
Just read the java main page again and it says Java basically I'm fooked as my W10 uses Edge, I'm trying a Internet Explorer Java download to see if that will work.
8,253
It should be easy but not proving to be so, yet I have followed the wiki step by step for all the downloads.
3,027
Do you have a link to the JAVA configurator?
3,027
Do you have a link to the wiki?
3,027
Is this the wiki you are using? If so, which numbered step are you on?
3,027
I wouldn't touch Edge or Internet Explorer with a bargepole, I use Firefox:
3,027
Once the JAVA runtime environment has downloaded and installed, it should work for all browsers present on your PC, unless it has been disabled. It will work for all programs on your PC.
This page will tell you if JAVA has been installed for your browser:
3,027
Once JAVA has been downloaded and installed, any .jar file will open using JAVA.
Step 5 on this wiki won't work unless you have installed JAVA:
3,027
Once installed, the JAVA language with libraries (plus libraries you install), are available for your PC running within your OS, and also your browser.
3,027
I don't run JAVA on any of my PCs at all anymore, because it's full of security holes. Unfortunately, you have to use it.
3,027
You're not at all fooked!
Related Articles
