Woosh King meter headlamp function DWG22C kit.
chris667
164
108
Hello
I see references in the manual for my meter to a headlight function.
Is a headlight something I can fit to my DWG22C kit? I can always rebuild the front wheel with a dynamo hub but if I have a great big battery it would seem easy to have a headlamp feed.
16,509
Headlight function is not implemented on the km529 woosh sell.
Reactions: chris667
chris667
164
108
Fair enough. Maybe that is an out-of-warranty experiment when I get my BBS01ET. I want to try both. :)
3,023
The light circuit on the bbs01b is only 6V, and turned out to be too low power for me as headlights, so I soldered three 12V to 80V headlights to the 19.2ah 35V battery instead via an inline blade fuse (as kindly advised by this forum) and motorbike handbar switches. Much better.
49845
Unlithiumed pump was dry
49846
