In-line brake sensors - how to stop them moving?
pn_day
185
40
St Andrews, Fife
Hi all,
My commute includes some pretty poor roads so lots of bumping up and down. Sometimes the brake sensors move and cause the controller to cut out.
Currently I've been using cable ties but these tend to move after a while.
Any other ideas?
Phil
Alan Quay
2,351
1,076
Devon
I always strap mine to the frame with cable ties. It doesn't have to be anywhere near the brake end. If the bike has cable along the top tube the I do it there.
You've installed your sensor incorrectly. It should be the other side of the cable stop so that it's trapped between the cable outer and the stop, which means thst you need to cut about 50mm off the outer. Like this:
Can't you put it on the front cable outer where it comes to the first stop at the front of the crossbar?
