How many people are using there e-bike off-road?
SRS
848
349
South Coast
6,560
just seen it a wondered why i cant find it to buy or anything like it.
Izzyekerslike
455
415
Leeds, West Yorkshire
Reactions: EddiePJ
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
That was my thinking as well. As a rider, you shouldn't even be looking at anything that close. Any defects or objects in the road should have been registered way before that point and preparation/ avoidance already made.
That device is just going to create target fixation, and have you off.
SRS
848
349
South Coast
I had forgotten about another negative with the Fenix BT20. You will need a battery charger that takes individual 18650 batteries. The light doesn't come with one, and by memory, it might not even come with batteries.
You might want to check before making any decisions.
This light seems to be attracting some good reviews. http://www.mbr.co.uk/reviews/lights/magicshine-eagle-m2-2400-light-review
Magicshine Eagle M2 2400 lumens bike light 2016 model ordered.
Shall give a review when I've tried it.
Reactions: EddiePJ
SRS
848
349
South Coast
Probably because it's a crap idea.
Just seen this and I agree.
If you actually add a light to see where you are going the grid would be invisible anyway.
Think i'm going to invent something shi*e. Wait a minute, I did once and nobody bought it!
Reactions: Westoe
Gez
15
Ribble Valley Lanc's
I've been using a haibike sduro allmtn RC all off road use in NW England since Sept and have ridden it in all weathers and fairly arduously off road. Within 50 miles one of the rear suspension pivot bolts nearest the deraillieur came loose and fell out. Replaced in double quick time by bikeshop24 (German based seller). Now the bike has developed an electrical fault where it won't switch off and boots up as soon as the battery is fitted, this fault develops to a total electrical failure (my guess as an engineer is its due to water ingress to the motor). fault reverts back to the wont switch off fault when bike dried off. bikeshop24 have quickly sent out a wiring loom and display in order to pin down the fault (FFBS: fault finding by spares). fault still exists. So looking like the fault is in the motor. i'll keep you updated. Anyone else got problems??
6,560
will prob need a replacement motor, do not open it as will void the warranty with bosch.
RobF
4,732
2,312
It would if the motor was a Bosch, but it's a Yamaha.
6,560
:oops: not checked Yamaha warranty so not sure then.
Gez
15
probably would with Yamaha too, the point at which the wires enter the motor via a rubber grommet which is on the top (so easy for water to sit on top of it) the wires are bent over to fit within the frame on assembly. this bend causes a visible gap (only small approx. 0.25mm.) giving potential for moisture/water to ingress it to the motor housing. I'd suggest that Haibike need to add an additional sealant to the interface between the grommet and the wires (X7). I've not seen a 2016 model to see if it's been remedied. Anyone have?
EddiePJ
4,632
4,013
www.facebook.com
Popped in to visit one of my mates today at his new cycle shop, and came away with an early Xmas present. :)
One 11-42 rear cassette, on one dirty bike, from yesterday nights ride.
I had anticipated a new rear mech and longer chain, but the only thing required, was a slightly longer 'B' screw. :)
