hollowtech pas sensor
lanerboy
43
55
midlands
Hi All
I have tried to buy one of these off oxydrive http://www.oxydrive.co.uk/store/index.html#!/~/product/id=63979&prid=39&ctid=11&tp=pv
But they say out of stock it seems everything is out of stock are oxydrive still going or have they packed up ???
Any way does anyone know anywhere else I can get one of these just the wire will do as I have a spare magnet ring so could manage with just the pick up sensor for a hollowtech crank.
LB
16,498
get a split disc and cut a hole in it with a 45mm holesaw.
lanerboy
43
55
midlands
Hi Woosh
Its not the discs I need its the bit with the wire attached to it that picks the signal up off the disc and plugs into the battery control unit and has a light on it to show it picking up the magnets
16,498
lanerboy
43
55
midlands
Hi Woosh
I have sent you an email as requested can you please conform it is the same as in the link above in the way that the sensor fits over the crank and sits at a 90 degree angle to the magnetic disc.
Cheers
Shawn
