LITELOK X Range - Angle Grinder Resistant Bike Locks
Outstanding angle-grinder resistance makes the Litelok X range the most secure armoured U-lock on the market. Protect your high value e-bikes & bikes.
Neither of those two are applicable to this new lock they're releasing.
Plus what do you mean about 'so called' I mean thats a bit of a negative when we've already seen this technology advertised and tested against grinder attack, where it wears the disc so fast any potential thief would need to change the disc several times.so called grinder proof locks
Locks tend to be "Grinder-proof" or "Cut-proof" - I have never seen a lock which resists both. If you have, please do provide links. Locks using new materials like this for instance, apparently resist grinding but not cutting (or vice-versa).Neither of those two are applicable to this new lock they're releasing.
I think you're being a bit too critical
'Or'Locks tend to be "Grinder-proof" or "Cut-proof" - I have never seen a lock which resists both. If you have, please do provide links. Locks using new materials like this for instance, apparently resist grinding but not cutting (or vice-versa).
They all go out tooled up, and the worry is discovering one has brought fists to a knife fight. Or knuckle-dusters or machettes. After the thief has been relieved of his angle grinder, he'd very likely whip out a big serrated blade, then it'd be angle grinder vs knife in a colosseum-like street environment. In the video, the small aggressive bike theif has made the alpha on the opposite side back down. If his accomplice didn't scarper, he could randomly stab intrepid heros within arm's reach from the other side of the railing. And it's not just knives and machettes - a friend years ago almost had his heart pierced by a long hat pin (or shaprened knitting needle, or some other kind of metal spike), expertly plunged into his chest by a "Off her head gypsy woman". He was a gigantic bouncer with a very interesting knuckle duster collection, some very old. And there's also the danger of the surprise gang member, who attacks unseen - a Shotokan Karate black belt I knew rapidly floored two muggers who were attacking a woman outside his home, but a third hit the back of his head with a brick. He's lucky to be alive - in hospital for weeks. He was far less confident after that experience. Knives are a reason why I cycle with a padded leather jacket - I have a fantasy that I can use it as a bull baiting cloak, trap the knife safely inside, and go on to mete out physical justice upon the attacker with extreme fisty prejudice. The other reason is for graze resistance, for the next time I fall off the bike and land on my head and arms. Leather trousers are a bridge too far.Obviously grinder boy is alpha male take him out and the others will cry off.
They servive on intimidation and fear, no more then the school bully does but will shite themselves when retailated against.
