Hi All,
Can anyone she light on the various standards for disc brake mounts? I'm interested primarily in the front disc as my Whisper only has a front disc which recently seized up. (By the way if anyone has a spare Tektro IOX I'm looking for one here).
So my options are either sourcing a replacement IOX allowing me to use the spare pads I already have, going with the new Whisper supplied Tektro Novela or finding something else.
I've been pouring over the various options, made all the more complicated by certain sizes being out of stock at various suppliers and no mention of available adaptors and omission of what type of mounting they should fit...
I'm also torn between hydraulic vs mechanical. On the one hand hydraulic shouldn't need adjusting but I lose the electronic cut out on the front brake (unless I can jimmy some sort of pressure switch - yes I know, 'jimmying' something as critical as a brake isn't really the right way to put it, I actually meant over engineer a solution ).
The mechanical callipers need regular adjusting and pad wear isn't very even, plus as I have discovered, the adjusters seize solid rendering them useless.
Whichever way I go, I'm still a little confused as to the types of mounts on forks i.e. post mounts or IS.
Also does anyone have an opinion on these brakes?
Shimano Nexave
Clarke CMD-8
Clarke S2
Tektro Agura Comp
Shimano Nexave
Clarke CMD-8
Clarke S2
Tektro Agura Comp
