First attempt ebike conversion
RollingChunder
To me, a motorbike would suit you better. Getting a motorbike license is extremely fun and riding the thing is so much more exhilarating than an ebike. I have ridden a 1500w throttle ebike and it's a novelty going 30mph on a bicycle but its not as fun as being the fastest thing on the road. It's only 2hp after all.
My ebike is a tool that allows me to commute 12.5 miles on a bicycle instead of taking the car or motorbike. I try to use the battery as little as possible so I get more exercise. It's boring if you sit there at 15mph doing nothing (I've tried it). I'd recommend getting something you could at least pass off as legal as the only time you'd get to use 30mph would be on main roads where you get overtaken by cars and lorries anyway.
Apples24
13
It’s not so much the top speed it’s the grunt for the hills I’m prob 21 stone
peddling is deffo what I want to do but I want a bit of both if I want to pop a Mike to the hop uphill without peddling atal I can
16,507
direct drive motors are not very good for heavy riders.
You need good torque. Direct drive motors have poor starting up torque.
For your weight, a crank drive is best, a large geared hub like my DWG22C is also suitable.
Benjahmin
2,497
1,706
69
West Wales
If you want the assist for hills then a direct drive motor is definitly a waste of money and time.
They are good at high speed on the flat. On hilss, as the rpm falls, they become battery gobbling heaters.
Despite repeated nudges towards a legal geared hub you seem to be persisting on following this big numbers motor dead end.
As has been pointed out several times now, a legal geared hub (rated at 250w continuous power) will actually give you 7-800w on hills, depending on controller setting. As the power will reach the road far more efficiently than any direct drive motor, this will give you more usable hill climbing power without overheating.
You would also end up with a bike that is not liable to being seized.
I recently took a direct drive motor off a bike I was working on, it weighed a mighty 8.5Kg in it's wheel.
It's replacement geared hub was a little under 5Kg in it's wheel.
The direct drive is a 48v Dillenger of unknown rating in a 26" rear wheel. You can have it if you want it. PM me and pay the postage - it's yours.
Reactions: Az. and flecc
RollingChunder
As above, a geared "250w rated" hub motor is what you want. 48v battery and controller, a good amount of amps on both but research on how much current you can put through the motor before gears melt and strip (not a problem for direct drives).
Does this have plastic gears? How much sustained wattage have you seen them take?
Peter.Bridge
722
329
Not sure a Direct Drive hub is what you want for what you are describing - either a geared hub like the Woosh DWG22C (48v 17amp max power input) - (which is legal to use on UK roads) or maybe a BBS02B crank drive (48v 25amp max power input) (which isn't legal on UK roads) - can get with 20Ah battery for £650. The advantage (and disadvantage) of the crank drive is the power is going through the gearing / drivetrain - so you get the gearing up hills with the motor still running in it's power band and potentially a high top speed , but will wear chains / cassettes (not designed for that power). FWIW, for road use ,I find my geared hub drive more relaxing to ride. Those Direct Drive hubs are also very heavy.
2,166
You know that you can make good wind generators out of them?
Apples24
13
So what’s benefits over a geared wheel hub motor over a direct drive one?
16,507
So what’s benefits [over] a geared wheel hub motor over a direct drive one?
Geared hub motors have a typical internal 1:5 gearbox. The torque is 5 times higher at low speed.
Apples24
13
I see they go up to 500w
too speed isn’t tooimportant but I worry woukd one get a 20 odd stone lump of a man around
if it woukd get up a good hill without peddling then it would be fine , but a 1500w direct drive one on that fat bike did too but watched battery go down a couple bars
Maybe I’m caught up on power figures but I’d hate to spend all that money and feel it’s not powerfull enough
I’m not worried about police I’m not going to ride like an idiot
Az.
1,356
603
Plymouth
It is enough for police to see 20 stone man travelling up hill without peddling on a bike with dinner plate motor. It is not a rocket science really.
Why won't you buy yourself a moped?
3,018
@Woosh - tell @Apples24 about your new bike, the WOOSH BIG TORQUER BIGGER TROUSERS™
...or about the alternative .hex file for your new TSDZ8?
Reactions: Woosh and Az.
Peter.Bridge
722
329
16,507
the Q128H is good but not as robust as the DWG22C.
Reactions: Peter.Bridge
Apples24
13
I dont want a motorbike if I want to go out in a toy I have a escort rs turbo for a bit of fun
16,507
From a purely engineering perspective what would be the max controller current at 48 V you could put through the DWG22C
it's as robust as the the Bafang BPM cassette version which is its (more expensive) cousin. IIRC, saneagle pumped 1kw through his BPM.
Az.
1,356
603
Plymouth
Motorbike is exactly what you are looking for. You just want pedals attached to it for some reason. 2000W is not 8% or 15% above legal limit. It is 8 times the legal limit.
56279
3,018
Would 20A X 48V = 960W at the crank utilising appropriate gearing for a 20 stone rider be a good solution? I don't know if 20A is enabled by the alternative .hex file @Woosh has for his new 750W rated TSDZ8 motor, labelled and legally rated as 250W. And it's torque sensored, possibly not as easy as cadence sensored motors, for heavy riders tackling hills?
