Disabled cyclist; with one bad choice behind her, needs help with a new bike
Katymac
160
43
56
Norfolk
I know what I don't want (I already have that)
I need a low step through, with shedloads of power to take me not very fast, everywhere, even up hills
I needs to be light, with big wheels, suspension, very sit up and beg
In fact a complete cross between the 2 bikes I have
The crusa is too heavy and all the weight is at the back so it's unstable when I walk with it or load it on the train
The fazua is too big for me I can't get my leg over the bar and my legs aren't strong enough to register on the torque/motor
3,015
Reactions: Katymac and Woosh
matthewslack
1,632
1,207
I plead not guilty.
TESTING, TESTING..... -1
Oh, this is fun! Such power! I wonder if I can vote twice to cancel that out?
Peter.Bridge
707
327
Or
Or
Or
Or
They are mostly rear rack battery / rear hub so will all be a bit rear heavy but you probably need to try them. I think the rambletta is the lightest of those (around 20kg) which is 4kg lighter than the Cruser
I think Wisper had some ex display models at a discount
Reactions: Katymac
Peter.Bridge
707
327
Loads secondhand eg on marketplace
6,339
56757
see if you can get the lap record on it round the local tesco id not bother paying just dont go over 250 quid and out the door going 60mph g4s has no chance :p
3,015
@Katymac hasn't said if shoplifting is one of her hobbies, but I hope it is. That certainly looks like an exciting activity, but probably not worth it for anything under £250.
6,339
they cant get plod involved under that amount all they can do is ban you from the shop.
bit hard when you can hit 90mph :eek:
6,339
Reactions: guerney
3,015
Trouble with that is databases: facial recognition at self-checkouts when shopping at other stores will flag you, and you'll get banned there too. Over time those databases will become larger and shared by more shops, and eventually you won't be able to shop in person anywhere.
6,339
i have halo armor ;)
3,015
6,339
6kw 60mph and 60 mile range will do me under 25kg ;)
3,015
That's possible right now with overhead electrified tram lines and supercapacitors! Sod all this heavy, expensive and dangerous battery malarkey for electric vehicles.
6,339
3,015
What does the Crusa weigh? How heavy would be too heavy? I think @Peter.Bridge's suggestion of trying a few out is a good one.
Alternatively, perhaps you could make the Crusa lighter by using a smaller battery? A battery expert might weigh in here, but perhaps you might not lose too much range, if a custom battery was made with the right high quality cells? This probably won't reduce weight by much.
Reactions: Katymac
Katymac
160
43
56
Norfolk
Sadly as a shop keepers granddaughter I go back and return a 2p if I get too much change so shoplifting isn't for me, even if the staff at Tesco didn't know me by name
The crusa is about 25kg (acc to the website) but panniers with a weeks shopping or going away for a few days plus a decent lock.....?
The centre of gravity is a problem too
I tried the Rayleigh Motus a couple of years back and couldn't get to the top of my hill, darent even try on the Fazua as I can't get to the end of my road!
6,339
i tip my local shop 11p every day id not even bother with tesco and can get my bog roll from china ;)
