its holding the housing on at the moment, the bolts that was supplied with it aren't long enough.Is the cable tie necessary, or do you see a potential problem?
If I'd looked closer, I would have seen that, of courseits holding the housing on at the moment, the bolts that was supplied with it aren't long enough.
Looking good so far, i'm just wondering if you filed the forks deeper as well as wider (as d8veh mentioned) to centralise the disc/wheel, I had to reduce the outer diameter of the outer washers to fit the recesses and to fit above the lips. Being a bit belt and braces, I also fitted a torque arm.yay, it worked, thanks d8veh.
as you can see from the pics, my seat post tube is to wide for the controller housing so I have zip tied it on for the time being until I can get some longer bolts.
also you might notice that I have no front brake, this is due to the calliper being to wide and close to the electric hub so I have to get a 180mm rotor and adapter so that it misses the hub. and I need to change one of the tyres as they are completely different at the moment.
plus the wires coming out of the controller box are showing so I need to sort them out too but apart from those 4 things its looking quite smart I think.
Trek tubes are super-chunky .as you can see from the pics, my seat post tube is to wide for the controller housing so I have zip tied it on for the time being until I can get some longer bolts.
Thanks for the link, it does seem that the best bargains are on line though I really would like to try for size before I buy.Hi link for diamondback great bike only 20 inch frame but 27 gears and 180 rotor on front £535 free delivery Hydraulic disc brakes brakes
Diamondback Response Comp 20" Hardtail Mountain Bike - RRP £745 | eBay
Frank
This is very true, if you have mounts on your forks and on the rear just above the rear drop out and have the rear wheel hub compatabilty for a disc then you will be able to fit your own mechanical disc brakes. Save some money that way.You don't have to buy a bike to get 180mm disc. You cn get them on Ebay for about £7 You need the 160/180mm adapter too.
180MM ROTOR FOR MTB BIKECLARKS WAVEY DESIGN BRAND NEW INC 6 BOLTS FREE P&P | eBay
This type for side mount:
[Bi_King] BENGAL IS Mount Disc Adaptor 74mm-51mm For Front 180mm Rotor Red SC11A | eBay
This type for post mount:
Shimano Spares Adapter For Post Type Calliper, For 180 mm Post Type Fork Mount | eBay
Rather than buy a new bike for conversion, you can get bikes as good as new for less than half price on Ebay, Gumtree, Preloved and facebook local ads..
Thanks for that but my bikes are so old that I don't have disc mounts.You don't have to buy a bike to get 180mm disc. You cn get them on Ebay for about £7 You need the 160/180mm adapter too.
180MM ROTOR FOR MTB BIKECLARKS WAVEY DESIGN BRAND NEW INC 6 BOLTS FREE P&P | eBayThanks
I found the same as you with the throttle and have it on the left.Some things I've noticed on my bike that I need to change after doing about 30 miles on it so far...
I'm used to have full suspension bikes and a hard tail is a bit rough on my rear cheeks so I will be investing in a suspension seat post as soon as I can.
I put the throttle on the right hand side thinking it would feel the correct place to have it but now I've noticed that if and when I'm climbing a hill I have to take my thumb off the throttle to change the gears as I have the thumb shifters, there are 2 things I could do here 1. Is move the throttle to the left hand side as I never have to ever change my crank chain at all or 2. I was thinking of getting the shimano dual control shifter because the brake and gear changing is all controlled by the brake lever, I had these on my last bike and loved them so for now I'm changing the throttle to the left and then when I get my new dual control shifters I can have the option of moving it back, also on a plus note with these shifters they don't eat up as much room on the handle bars so makes a nice fit on any bike.
That's the couple of niggles I've found so far and hopefully that should be it once I've sorted them out.
I know what you mean. Got combi-shifters on my Trek .. older XT-type.. and went to great pains to retain them when putting the build together. If I'm using the throttle on the RHS I can change up the rear cassette using my index finger whilst keeping thumb on the throttle. Obviously going back down it is just a case of pushing down the brake lever with top of the palm. Works fine, especially in traffic.I put the throttle on the right hand side thinking it would feel the correct place to have it but now I've noticed that if and when I'm climbing a hill I have to take my thumb off the throttle to change the gears as I have the thumb shifters, there are 2 things I could do here 1. Is move the throttle to the left hand side as I never have to ever change my crank chain at all or 2. I was thinking of getting the shimano dual control shifter because the brake and gear changing is all controlled by the brake lever, I had these on my last bike and loved them so for now I'm changing the throttle to the left and then when I get my new dual control shifters I can have the option of moving it back, also on a plus note with these shifters they don't eat up as much room on the handle bars so makes a nice fit on any bike.
I going to give that a go on Monday, it's my week end off so I'll be pottering about doing a few small trips. I live on a hill and I have to ride down it first and then over a small hump back bridge so I will try not using the throttle for the first mile or two, I think because it's so new I just want to use it all the time but I know as soon as I'm used to the mileage I'm doing on a daily basis I will use it a little less.I find that If I'm doing a longish ride and I don't use power for the first mile or two, it feels great when I start to use it, also when I go to pedal power only it doesn't feel quite so much of a drag.
Probably all in the mind but it works for me, no good if you have to climb hills straight away of course.
As I'm very new to this though not to cycling, it's great to hear someone else's thoughts which seem to back up my own experience.
Hi Ray..... I was looking at the pics of your bike in this thread..... it looks great and the kit incorporates really well into your bike. I especially like the black colour of the bottle battery, seems less conspicuous than the silver colour I've seen these batteries in.I going to give that a go on Monday, it's my week end off so I'll be pottering about doing a few small trips. I live on a hill and I have to ride down it first and then over a small hump back bridge so I will try not using the throttle for the first mile or two, I think because it's so new I just want to use it all the time but I know as soon as I'm used to the mileage I'm doing on a daily basis I will use it a little less.
hi yamdudeHi Ray..... I was looking at the pics of your bike in this thread..... it looks great and the kit incorporates really well into your bike. I especially like the black colour of the bottle battery, seems less conspicuous than the silver colour I've seen these batteries in.
Was there any reason you went for the Cyclotricity kit instead of the 8fun kit ?..... Also was the controller case included with the kit, and is there any possibility of the controller overheating being enclosed ?
