Controller LCD-P3C E-bike UrbanGlide C7
Frederico Vicente
12
44
Aveiro - Portugal
Hi, Frederico ,
Mine isn't working, unfortunately, have you done anything special to get it to work? is it only for charging?
I didn't do anything special, I just plug in directly as much as I need to load something.
But, your case must be some problem in the controller, because the usb is always active I don't know any parameter for this.
I will try to understand better
Compliments
Holzmichel
Hello everyone, I also have a Jeep Fold 7022/7024 with the same display with password protection, unfortunately 6666 doesn't work for me either, and support doesn't know the password either, does anyone have a manual for this display to reset the password.
I would be very thankful for help.
Holzmichel
Hello, yes I tried, unfortunately it doesn't work, enter the password and then press ok (on/off button) You don't get any real information from support either, I think they don't want to give out any information, well the bike will probably be sent back to them With these factory settings, the bike runs like ****.
Reactions: eSabit
BenjaminDk
Feb 22, 2022
Good night everyone. Hope you all are well. I have a question and can't find anything on the internet that would help me, so I ask for help.
When I go to the configuration of the controller of my bike, show "- - - - " these dashes, I believe it is to put a password...
Would you know if the password is universal standard or brand-specific?
Here's the photo of the controller...
The model of my bike is;
UrbanGlide E-bike C7
Hello :-D I bought an UrbanGlide c7 and have messed up its parameters. Can any of you please send me its default values? thanks in advance. Sincerely, Benjamin
Holzmichel
Hi Benjamin, I have a jeep fold FR7022 but they have the same controller and almost the same settings, those were my original settings but unfortunately I have to translate I'm from Germany, hope it helps you anyway.
P 2 is km with me and P 3 36 V
Reactions: BenjaminDk
BenjaminDk
Feb 22, 2022
Thanks. You are the best! now it pulls to 25 km/h again .. do you know how I push it to 40?
Holzmichel
You can set the Speed Limit parameter high, but I would advise against it, the engine has no temperature display and you don't know how hot it will get, this will only damage the engine, the stuff all comes from China, so be careful with it. I have 27 km /h I live in the city and that's more than enough. :)
eSabit
Mar 10, 2022
Hey, Michael!
I have the Jeep FR 7020 with the same LCD-P3C
How did you manage to bump it to 27km/h?
Code 6666 doesn’t work for me either.
Cheers!
Holzmichel
HI, don't quite understand the question? if you enter 27 km/h maximum speed in the parameters, you can also accelerate up to 27 km/h. My password was 9999.
Holzmichel
To get into the parameters, press plus minus together, then four dashes enter the password and press and hold the on-off button longer.
Holzmichel
HI under p 17 you can switch the crusie mode on and off but I think there are only 2 levels 0 off and then 1 and 2 which speeds they are I can't say unfortunately my bike doesn't support a cruise mode.
Holzmichel
either it's in the manual or just google it, there's nothing in the manual because it doesn't support my bike at all Jeep Fold 7024.
MarioZ87
Jul 7, 2022
Do i have to alter bike mechanically to deactivate speed restriction or it's possible by simply changing max speed on display?
Micheleowowwow
Nov 18, 2022
Puoi impostare il parametro Speed Limit alto, ma te lo sconsiglio, il motore non ha il display della temperatura e non sai quanto si surriscalda, questo danneggerebbe solo il motore, la roba viene tutta dalla Cina, quindi sii attento con esso. Ho 27 km/h vivo in città e questo è più che sufficiente.:)
[/CITAZIONE]
VENIRE SI Attiva
