Computers and stuff...
3,018
cant make tech without gold and silver ;) but a line of coke with a 50 rolled up is all it is good for :p
Tried to buy a bike with cash, seller said "No £50 notes!"
Never tried the stuff, but a very old mate who's CEO for a big advertising company in New York, says his company is chock full of coke. Literally everyone is hoovering it up by the kilo. Big part of advertising culture, like Hollywood and the music biz. And the middle class in the UK. For something so illegal, it sure is widely available.
6,342
i just robbed it :eek:
3,018
I wondered when someone would get around to doing that - those useless things at my local Tesco Express are held in by just four bolts into what I guess are rawplugs of some kind, into tarmac. Looks like an easy long crowbar job. Bloody useless.
6,342
yup just need to get the angle grinder out to get rid of the d lock :p
3,018
I've seen the Lockpicking Lawyer use a hydraulic bolt cutter to cut through D-locks. Didn't take him long, as usual. Quiet too.
6,342
i can sell it for 30 quid each bit if i chop it in to single stands tho id hold off parking ur bike at my local tesco
3,018
You could sell them back to extremely small Tesco branches.
6,342
need a fkn pin drill for that as bit wont fit in the drill it is so small but i can lock it in to car mode for menasor mode but it broke because the screw was so tight.
57539
its a unstable wobbly mess why i never got the trailer
3,018
6,342
same one i bought lol
6,342
6,342
3,018
There may be a way to repair using superglue?
6,342
tried it and just snapped off again will have to drill and pin it even then it wont hold if you keep moving it
6,342
57655
not the part i got but the top part of the mushroom peg has snapped off and a super tight fit as holds both legs and top body on the part it all clamps to.
3,018
Which bit snapped off exactly? Have you got a pic? I've had success thickening plastic parts, after glueing together using superglue, then superglue and fine grain bicarbonate of soda around the break - you can build it up in layers to add strength, then file off what you don't need. But if there's no room for added material for strengthening, that won't be possible. The fine grain stuff is sold everywhere, on the baking isle of supermarkets. Sets fast to everything, including your fingers of course; a hard plastic layer. That combination is hard to remove if you don't have acetate (which also dissolves some paints and plastics).
You could try the stronger superglue + graphite. Make graphite dust using emery cloth/sandpaper and a pencil.
3,018
Gawds. Maybe bore a hole through it (top down through the mushroom peg), fill it with superglue + graphite in layers, to form a solid core? Dunno. If that and nothing else works, glue it all together and accept it'll never move?
6,342
put it this way if i took one totally apart and sent it in a bag of bits and screws you could never put it back together.
glue and masterpiece transformers dont work the joints are so tight and so small you destroy the paint wok if you move them, there not toys!
id rather work for foxcon than hasbro fkn things are like mac books every screw is a different size and shape and length loose one n ur fooked :oops:
6,342
thats Mattel
