Trepo nice pics BTW. The DeWalt packs have the advantage of being ready soldered together mostly with tags incl.
I get about 8-10 miles (13-16 kms) on my 2*6s pack depending on how much I pedal. What are you powering ?
I guess my Brompton/Tongxin combination are a low demand setup.
PS Aah I wonder if that is why my Turnigy screen messes up soemtimes in the cold ?
PPS Hopefully your Tongxin will turn up soon
Regards
Jerry
Thanks Jerry! Yes, your range seems to be about twice compared to mine.
It's probably due to the higher weight of my bike, its 35 kg all together (25 years old steel-framed trekking bike and SLA batteries worth of 15 kg). I myself weigh a little over 90 kg... yes, I know, I should eat more healthy and cycle more to get fit.
So the bike and rider are about 130 kg together, no wonder it takes 10 WHr / km. And my controller is a 14 amps unit, your Tongxin one probably eats less current.
It's now two weeks since they picked up my payment for the Tongxin kit in China. Hopefully the kit gets on the way this or next week! I already have all the other bits ready.
Today I had my second ride with A123 batteries (2060 mAh consumed until weak motor performance) and this time I am charging them with the same ebay charger as yours. Charging is going through Turnigy meter so I will update charged capacity to this post later.
I just have to monitor the end voltage that it doesn't get too high. Build and adjustment tolerances seem to be quite wide on these cheap chargers. My unit even had a bare negative charging lead inside, it had been chafed to the heat sink. I just insulated that part of the wire and the charger seems to be working fine.
The charging has just ended as of writing the post. Unfortunately I did not notice the peak charging voltage but the charger had green light and the pack rest voltage was 42,87 V.
Poli max B6 was able to push in only 20 extra mAh to the first pack and 27 mAh to the another one so this 36V charger seems to be doing good job. The cells were also quite well balanced (20-30 millivolt maximum difference).
Regards
Taisto
