Hi all,
I've got another naive question for the collective wisdom on this board.
I have extended a brake sensor cable (fitting into a recumbent velomobile, and the cable run was too long without extending). All seems good, except that the brake sensor only cuts the motor out (showing a brake indication on the controller) when the magnet is right next to the sensor. The brake sensors were kindly included by Woosh when I bought the GSM crank drive for use with an external controller. They are listed on http://wooshbikes.co.uk/cart/#/category/uid-4, described as a "pair of hydraulic brake sensors for BBS01/02".
I had to cut the end off in order to extend, and as it had a yellow 3 pin (Juliet?) connector, and the controller took 3 pin rectangular connectors (JST?).
I think I need it to operate the other way round - with the brake sensor cutting the motor when magnet is far away from the sensor. I attach an image of the control yoke showing the metal T-shaped brake lever (which operates 2 cable operated Sturmey Archer drum brakes on the front wheels). Not shown is the current cable-spaghetti that runs down it until I have everything working fully and tidy up!
Is it possible that I've connected something up the wrong way round? I thought it was just 5V, GND, and signal?
Thanks in hope,
Phil
Thanks in hope,
Phil
