Big Bear - Motor Gone?
16,507
lastly, connect the brake sensors. On the controller side, you have two identical grey/black 2-pin JST connectors:
Reactions: Peter.Bridge
16,507
I'm working it all out now and will go back to the bike in the morning.
Andy has gone home. I usually do out of hours support when the office is closed.
Do take one step at a time, it's easier to master the wiring that way.
PC2017
1,306
330
Scunthorpe
stever1957
131
43
66
Lake, Isle of Wight
Mornin' all.
Well red/black/blue turned out to be pedelec.
It connects to red/black/blue at the controller.
Red/black/white is the only one left, so that must be speed sensor, and the only one left at the controller for it to connect to is red/blue yellow.
Trouble is now I get pedal assist again, but for only one half turn of the pedals, then nothing for the other half turn. This repeats over and over.
I also have no speedometer.
I've checked all connections ad nauseam.
I've cleaned the magnet wheel and the sensor.
16,507
Let's fix first the pedal sensor.
Check that the magnet disc still has all its magnets and it turns correctly together with the cranks.
Check that the LED on the pedal sensor flashes correctly when you turn the cranks.
If the problem persists, can you email support@wooshbikes.co.uk some closeup pictures of the pedal sensor and the magnet disc, and also of the old controller so I can identify it? I can access the support mailbox.
16,507
Fixing things is easier if you and I are on the same page. Let's fix first the pedal sensor, when that works, then sort out the speed sensor. Leave the speed sensor unplugged. I need you to follow the suggested steps. There is a logic in what I suggested.
16,507
the main thing in troubleshooting anything is to keep the number of variables as small as possible. Let's sort out the pedal sensor first and leave the speed sensor disconnected for the moment.
2,165
I'd bet that you have the speed sensor in the wrong sequence. Disconnect it and see if the bike works properly. You must use a meter set to continuity test to determine e which of the red, blue and yellow wires is ground.
2,165
Which means I'll have to take the controller and all of that spaghetti out again to disconnect it.
Is it really necessary?
You shouldn't have put it all back together until it was working properly. Do one connector at a time. Use a meter to determine the connection sequence. Use logic. Test. Just putting random connectors together because they fit will only get you into trouble.
16,507
We know you have a working LCD, controller, throttle and trunk cable.
We know you still have problems with the pedal sensor and the speed sensor.
Follow these steps:
1. remove the battery.
2. undo the 4 screws, remove the cover of the controller compartment which has the battery connector on it.
3. pull the controller out of its compartment, put it on top of the controller box or pull it out sufficiently so you can see everything easily.
4. Slide the battery back half way so it still sits safely in its rack, then connect the battery connnector on the cover of the controller compartment to the battery.
Now you have the electrics connected and you can see everything easily.
Next steps:
5. Unplug the speed sensor and the brake sensor, leave the pedal sensor connected.
6. Test the pedelec function.
If that's working, next steps:
7. connect the brake sensor and test
8. Connect the speed sensor and test
9. disconnect the cover of the controller compartment from the battery
10. Reinstall the cover of the controller compartment.
11. Reinstall the battery.
stever1957
131
43
66
Lake, Isle of Wight
Follow these steps:
Next steps:
Thanks very much, Woosh.
I'll go through that sequence after this cup of tea (or tomorrow, if I'm too knackered).
16,507
Right.
speed sensor disconnected.
Pedal assist working like a dream
This is a result, as far as I'm concerned.
now we need some pictures of the speed sensor's connector on the wheel side so we can match them with the wires and connector on the controller side.
If you can't post the picture here, email pictures to support@wooshbikes.co.uk, I can repost them on this thread.
