Dear all,
A bit of a newbie question here again I'm afraid.
I want to pop in a watt meter temporarily between battery & controller as although I have the LCD3 that shows power, I soldered the shunt so it no longer shows the correct amount! The kit came pre-wired with Anderson powerpoles for the battery & power lead to controller.
(Battery is the 36V 20Ah shrink wrap http://www.bmsbattery.com/36v/445-36v-15ah-lithium-ion-electric-bicycle-battery-pack.html)
Anyone have an idea if I should be buying 30A rated Anderson Powerpoles or 45A?
And is this the best UK supplier of such connectors?
http://www.torberry.co.uk/superbasket/category/92/Powerpoles+-+15+to+180+amps
I'm hoping to use Hurricane's handy guide to how to do it without buying an expensive crimper from here:
http://wh7da.wordpress.com/2007/12/24/crimping-anderson-power-pole-connectors/
Many thanks,
Phil
Many thanks,
Phil
