2016 haibike all mountain RX for sale
6,325
mine are fox and have 150mm of travel and the max for mine is 200psi
tho if you have less travel than mine then it would be lower.
best way to get it right is just to ride it tbh then set it how you like. ;)
Reactions: Bertyo
mab13
153
120
45
Peak District
For what it's worth, I'm a similar height and inside leg to you... and I wouldn't dream of a 50cm. I hope you can get comfortable with your setting adjustments as I think 46cm is the right size.
Move the saddle as far back on the rails as the indicator marks will allow you to, if you've not done already.
Regarding your front suspension, max of 110psi sounds low... but it could be fork dependent. Your fork should have a small rubber band on it. Put that all the way to the bottom and do a bit of a rough ride, check where it moves to and then add or remove air depending on the amount of travel the rubber band shows you've used.
Reactions: Bertyo
6,325
Bertyo
12
Leeds
No m8 it sold, I do however have a mint 40 mile 2016 xduro all mnt pro for sale in medium
