Yosepower battery cut out
James Torr
16
Hey folks, I've a issue with my Yosepower rear hub conversion. It's a fairly senior kit, but I'll try to keep it going as long as possible.
Over the past few months, the power seems to intermittently cut out. I can't turn it on directly, but if I lift the battery off and remount, it will switch back on fine. I might get a few minutes ride, or longer, then it just switches off. I've cleaned the contacts on the controller, tried to tighten those on the battery as well. I assume it's contact related, if the supply is interrupted, it just switches off.
Anybody had (and fixed) a similar experience to this?
Thanks in advance for your responses.
3,761
If the LCD switches off, the power to it has been cut either by a connection fault or the battery's BMS shutting off. If it happens when the battery is fully charged and your LCD shows maximum bars at the time of shut-off, it probably a connection fault. If it only happens when the battery is run down a bit and you see the bars going down immediately prior to shut-off, it's probably the BMS. Once you've established which of the two situations apply, the cause will be easier to find.
James Torr
16
I'll check, but I'm pretty sure it's happening regardless of the charge status, I've never seen the bars going down prior to shut off. Just happens quite randomly.
James Torr
16
I've got a mate with the same kit, I'll check to see if his battery does the same thing, that should tell me if it's the BMS or not.
James Torr
16
I appreciate you trying to help of course, and I'll look out for the BMS diagnosis pointer you mentioned, which was of course, a given after you suggested the first time round.
8,736
How senior is the kit ?
Likey a shagged out battery possibly.
One reason why the BMS cut's out , the cells maybe hitting LVC to easily.
thelarkbox
1,515
473
oxon
The Hailong battery and its mount on my 2nd bike have both been through the wars with sun warped plastic and some of the securing lugs have snapped off on a very bumpy rd/track the battery can jump out of position momentarily disconnecting itself.
Strapping the battery down with a cable tie sorts it. dont overtighten the cable tie, that way it can be slipped on/off to remove the battery as required..
