Hello
Had the above kit for a couple of years now and been pretty reliable. This morning however on riding it I found that it was cutting out. I jangled the cables around a bit and it would usually come back to life but it does appear to be getting worse (this happened a couple of times in the last few days). Interestingly it appears to be ok again until I try and use the throttle when it then cuts out but shows on the display that I am using the throttle!
I recently disconnected everything to change the PAS and the bag holding the controller so it might be that things are a bit loose. I am going to try and spray each connection with contact cleaner (unless I shouldn't?) but other than that I am not sure what to do. Any experience of similar from you folks?
