Yose power 36V 250W 6km/h limit
malyglodzio
Jun 19, 2022
Hello, I installed a 36V 250W yose power kit with a C500 display on my bike. The problem is that I can only drive 6 km/h on the thumb throttle. How can i remove this limit?
PC2017
1,319
334
Scunthorpe
8,529
Not a KT controller with a c500 so more likely it is a Lishui lsw controller.
They will set for 6km/h as that is the legal position for their use, download a c500 manual via search and see if there are any settings that can be changed.
malyglodzio
Jun 19, 2022
Lishui controller. The display has settings, but changing these settings has no effect. I changed in advanced settings SET 4 and SET 5 without any results.
In general settings I have SET 1, SET 3 and SET 4. I don't have SET 2 and SET 5. In the advanced settings I have all from SET 1 to SET 7. Photos attached. (I wrote the default settings with a pencil).20220618_073629.jpg20220618_073637.jpg
Reactions: PC2017
8,529
It is likely hard set in the firmware then.
malyglodzio
Jun 19, 2022
Can I change the controller to 36V 350W? I saw that this controller has no limits. Will the engine burn out?
Is the motor in the yose power 36v 250W set the same as in the yose power 36V 350W set? I have the impression that these sets differ only in controllers. Can any of you confirm this?
Reactions: Ray Winder
8,529
Some displays might not allow the disablement of the throttle option, even if the manual says so.
2,755
Unlikely to harm the motor. Make sure the battery can cope.
Dannyai10_
Oct 9, 2023
I Changed the controller and the throttle is working normally. :)
I’m soon to get the 350w Yose power kit and I was wondering if anyone knew wether that was also limited and if so what controller would I need to buy to derestrict it as the main reason for me choosing this kit aside from low price is for the throttle. Thanks
PC2017
1,319
334
Scunthorpe
Its prob Lishui, you would need a KT controller that matches your connectors + LCD + throttle + brakes (all KT) and just keep the YOSE motor & battery if the battery rack is integrated with the YOSE controller you may have issues, if the YOSE controller is a box standalone then it will be easier. Lots on here about YOSE just use the Search and use tags like YOSE and KT - assuming the YOSE is not right for your application, try it first.
Reactions: throwawaychap
Cadence
272
204
The Yosepower 350w kits are not speed limited. I have bought two this year -one with an integrated 18A controller:-
36V350W 26"/27.5"/28" Rear E-Bike Conversion Kit for Cassette with 36V – YOSE POWER UK
and one with a separate 18A contoller:-
36V350W26"/27.5"/28" Rear E-Bike Conversion Kit for Freewheel – YOSE POWER UK
The max speed can be set in the advanced settings in the C500 display. The throttle can also be set to either 6 Km/h maximum, unrestricted, or set to the same power as each PAS level on the display.
3,133
In general settings I have SET 1, SET 3 and SET 4. I don't have SET 2 and SET 5. In the advanced settings I have all from SET 1 to SET 7. Photos attached. (I wrote the default settings with a pencil).View attachment 47712View attachment 47713
Your two throttle settings are set to "n". Shouldn't one or both be set to "y"?
Cadence
272
204
That post was from June last year! He solved the problem by changing the 15A controller that came with his 250w kit for an 18A one that Yose sell in their 350w kits (and available separately) See his post on 23 July 2022.
From my experience with a 250w rear kit, changing the controller will allow the throttle settings, but not the maximum speed setting. To do this as well the C500 display wil also need to be changed. The version that Yosepower sell separately will do this.
Bobbo1260
50
12
Did you find out if the throttle can be set to a limit of 6kph/4mph?
I didn’t see this covered but I did come across a setting in my display giving the option of throttle y/n which was full power of walk mode but it didn’t get up to 4mph with my fat @rse on the trike.
