Yamaha battery
Alvin89
13
9
West Midlands
Hi, Does anyone in the Midlands have a working frame attached Yamaha battery from 2015/16 that I can use to quickly check my bike. Bike turns on then off and I don't know if its the battery or motor that's the problem. Thanks
6,505
send the motor to peter if it is the controller he can replace it.
chris_n
737
440
Niedeau, Austria
Have you been through the troubleshooting that is in the manual (many copies online). No way would I put my battery on a suspect motor to prove which part is faulty when I could end up with a battery locked out with a fault which the motor has caused.
Alvin89
13
9
West Midlands
Thanks, I will go through the troubleshooting again. Is it easy to remove the motor or do you know someone who could do this?
