Yamaha battery 500wh pinouts needed
Nov 10, 2006
178
14
Midlands
Yamaha Intube 500Wh 36V Battery has anyone got the pinouts? How is this charged off the bike? Does it need a different BMS to use on another bike?
6,398
i bet it wont even turn on unless it is connected to the motor or even get a voltage out put from the connector.
so it could work imo with a new bms but with those bbatts you will destroy it just cracking it open so if it works sell it.
Nov 10, 2006
178
14
Midlands
I have 36ish on the larger connectors so I know I'll get supply. That isn't an issue really. It's whether I can charge it stand alone. Looked at the official chargers and they are ridiculously expensive. Whether someone managed to find a suitable replacement charger would be helpful tbh.
6,398
tbh where did you get it from as sounds a bit dodgy you have no bike to fit it in or a charger.
oem batts and chargers are expensive for these bikes and those are rather new that fit in the down tube.
Nov 10, 2006
178
14
Midlands
I can assure you it is above board. I'm simply asking whether anyone has worked the pinouts. Thanks for your concern though. You came across as pretty blunt and quite rude so I'll block you from this point.
  • Disagree
Reactions: Nealh
6,398
yay like i said sell it its worth more as is than you trying to make it work on anything else ;)
3,990
He has every right to say that. It sounds dodgy to me as well. Could you explain how you came by this battery and what its serial number is to put us at ease?
Nov 10, 2006
178
14
Midlands
I'll pm you thanks.
Nov 10, 2006
178
14
Midlands
Notes on the BMS interesting review.
3,990
Nov 10, 2006
178
14
Midlands
Thanks vfr I'll start translating!
