Wuxing 108X Throttle
davell
155
64
Doncaster
I have a T-06S controller and KT-LCD8 on my bike which are working great. The only issue I have is with a Wuxing 108x throttle. It doesn't seem to be very linear. There is a very narrow band of lever movement between no throttle and full on (500w on display). It's difficult to use with intermediate power levels. Is this normal with these throttles? Are there any settings I can adjust that may affect this?
3,994
Do you have a pedal sensor? Some KT controllers change their behavior depending on whether they get a signal from the pedal sensor or not. If it receives a pedal signal, throttle is only zero or full. Without a pedal signal, throttle is proportional to twist.
I'm pretty sure that P3 changes that, though I've never tested it. Under speed control, I think the throttle takes precedence.
C5 can also have an effect, as values 0, 1 and 2 determine how the power ramps up.
Reactions: davell
