Well, I've done it !
I settled on the Cyclezee kit because it had everything I needed. The conversion took about 5 hours. Everything went as per the instruction sheet apart from mounting the rack. I ended up having to make a bracket to suit the frame. It's a bit rough and I will be refining it after the sheer whoop of riding this beast up welsh hills has worn off a bit.
I had to ditch the fitted combined front deraillier changer/brake lever as it collided with the throttle housing. How naive was I ? Who needs 3 front rings with this motor ? So I fitted the supplied switched brake lever to the left side.
There's a lot of cabling to keep tidy, I think there must be a Kg of cable ties and self amalgamating tape to keep it in order.
I'm currently in battery conditioning phase, two complete discharge cycles, to flatten this baby takes some doing (I went for the 14Ah version). So I'm finding the steepest hills around to try to get this done. I still can't quite believe that, on setting 5, this thing will drag me up whilst merely rotating the pedals.
But mostly I'm riding on setting 2 allowing me to still get some heart pumping exercise. This is a large motor and when it kicks in it's quite a jolt. Some people have mentioned the noise of motors, yes it does make a noise but I find in any sort of traffic this disappears. Assist level change is instantaneous the only delay being on initial start up when it takes about two pedal revolutions to get motor going. This is the only time I've found a use for the throttle.
Obviously the handling/weight distribution is totally different and, on tight turns, this is taking some getting used to. There's some fine tuning to do on brakes and gears but overall I'm really pleased, neigh excited like a 12 year old !
I am having some small problem with the front light, hence the coiled up cable on the back rack. Nevertheless Cyclezee has been really helpful with advice and sorting things out.
So, I enjoyed the process, I haven't done any work on a bike since I was about 15, and I'm already trying to find a reason for doing another.
Any comments welcome.
Ben
