Woosh Gran Camino
17,055
What is the weight of the above ebike?It states in the spec approx 24kg but it's far in excess of that I think?
The 24kgs is the weight of the bike ready to ride, including saddle, pedals, bell, lights, mudguards, chainguard, battery.
Raboa
826
308
52
If you go onto the website and look at the description of the bike.
Internal cable routing is spelt inernal cable routing.
Hope this helps
17,055
Hope this helps
webpage amended. Thank you for pointing that out.
17,055
May I suggest you re weigh the bike.Mine is so much heavier than 24kg
How do you weigh your bike?
I place a 2m plank of wood over the scales platform then zero the scales. I place the bike on the plank.
naiad
13
LN12 East coast
Same method surely the G C is heavier than the Santana?As I get older I'm thinking a step through may be better for me but the weight concerns me.I just would like a weight comparison between the two.Please re check the weight of the GC.Thanks
17,055
They have practically the same weight. The fork on the Santana3 is suntour NEX, it has aluminium lower legs, a bit heavier than the Suntour XCM fork on the gran camino. The frame of the Santana3 is also slightly heavier. The Santana3 rack is heavier and the Santana3 crankset is also heavier. The motor on the gran camino is slightly heavier.
17,055
If weight is important, a kit is the way to go. An aikema/Tongsheng 85SX motor weighs less than 2kgs. My full sus bike with the Tongsheng 85TS kit weighs 14kgs with 48v10ah bag battery.
matthewslack
2,246
1,545
Don't keep us guessing! How much more?!!
2,801
It looks as if almost everything on the Santana3 is heavier, so how do they end up practically the same weight?
17,055
The Gran camino has a beefy dwg22c motor, the Santana3 has the lighter bafang swx02. The gc has 500g of motor + 100g of spokes more. The gc has 12 gauge spokes front and rear.
AntonyC
348
150
Surrey
The times I notice the weight of my GC are when lifting it through a doorway and at unexpected stops, so not that often, and if the throttle hadn't given up the latter wouldn't be an issue - once on the move you wouldn't know. I rode a large motorbike so I'm in the habit of straddling a bike fairly wide and with the brake on.
naiad
13
LN12 East coast
I have to apologise you are quite correct!!My method of weighing the beautiful bike was incorrect!!Sorry Woosh
