Hi All,
I applied for a ebike through my works cycle scheme and have been eagerly researching what would be most appropriate for my daily commute, and finally decided on the Woosh Big Bear LS.
The reason i went for the LS version is so that my other half can also use the bike.
The bike arrived this afternoon, and after spending a good bit of time unpacking it(never seen something packaged so well). The battery came fully charged which was a surprise as I was expecting to charge it overnight.
I had the original twist throttle replaced with a thumb one(based on general feedback about twist and go throttles on here) and also had marathon plus tyres installed.
I have just been out for my first ride, and rode from home to work and back. Cant believe how much of a difference the electric assist makes. The ride was the most comfortable i have had, even though part of the route is down a disused / private road which appears as if its been aerial bombed.
Its going to take me a few more rides and hours to get used to the assist as it can be a bit disconcerting at the highest level as it feels like the bike is going to run away from you,and then when it hits the legal limit and cuts out.
I cant fault woosh (thank you Hatti and Andy) through the whole selection and order process. If my other half gets the ebike bug, my first port of call will be back to woosh again.
Cheers
Cheers
