Five Year Review...
I'm Very Happy with this Machine. I wanted something as British as possible, reasonably priced, and Durable, This is what I Got for £1249 with the Bigger Battery..
The Battery seems every bit as good as new at holding charge. Recently I had to replace the rear wheel, which was quickly supplied at a reasonable price by Woosh.
A couple of years ago the main pedal spindle was swopped. It's had two new rear tyres&tubes. I've replaced the rear cogset/freewheel for a DNP 7 Speed (£30) which means less frantic pedaling at full pelt!
The worst problem was it stopped powering the bike when pedaling. However the throttle switch still worked. This was worsened by incorrect diagnosis that it was the ecu in front of the battery, most troubling, resulting in two hour + intensive research.... Stripdown&Inspection.... Turns out it was simply the hall sensor that detects the small spinning magnets in the plastic disc... £11 from Woosh, I also replaced the plastic disc, £20..
I never use it in the Rain, very occasionally get caught out in a shower for a few minutes, and have no complaints, the machine has around 2000miles recorded...
It still feels very new to Drive...
I'd encourage anyone to learn to do your own research&repairs, The Local Halfords&Bike Shop are untrustworthy, both in knowledge, advice and sales IMO
Would highly recommend Woosh...
Thank you for Reading,
Jesus is Lord
Shalom
Woosh Bikes
Woosh Bikes Ltd Electric bikes and kits assembled in Southend-On-Sea. Affordable and comfortable e-bikes to suit every pocket.
Jesus is Lord
Shalom
